Old 03-31-2008, 08:16 AM   #1
Irishpilot
drum brake help
I can't get my drums off and I'm wondering why. I've tapped on the backs trying to knock them loose. I've tried prying them off and it feels very solid. I'm running out of patience so any ideas would be helpful...
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 03-31-2008, 08:22 AM   #2
ed2552
ed2552's Avatar
Re: drum brake help
They are adjusted too far out, you need a brake spoon and possibly a small flat screwdriver, stick the spoon in and try to adjust, if it doesn't turn, take the screwdriver and put it in the slot and pry up while turning the spoon. Sorry, this is the best way i know to explain it, someone else will chime in and explain it better, good luck!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-31-2008, 09:15 AM   #3
sandking
.....I am working on it.....
sandking's Avatar
Re: drum brake help
I had the same problem on my '72. I used WD40 around the center hub, then pry with a big screwdriver. Like ed2552 said, make sure the adjuster screw is loose so the pads are free.
sandking is offline   Reply With Quote
Old 03-31-2008, 09:44 AM   #4
Cyclone44
Step Brother
Cyclone44's Avatar
Re: drum brake help
I had to do the same thing on mine...
Cyclone44 is offline   Reply With Quote
Old 03-31-2008, 05:54 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: drum brake help
....yeah, because as the shoes and the drums wear, a lip can form at the outer edge that will keep the drums from slipping off. It's a pain at times, but it can be done. Just be patient....and back those adjuster off so the shoes can retract away from the drums. It may take a while, but it will work.
Member Nr. 2770
Old 03-31-2008, 06:15 PM   #6
cdowns
cdowns's Avatar
Re: drum brake help
if you're trying to remove front brake drums and they're still riveted onto the hub you'll need to either grind the rivets off or remove the spindle nut and the wheel bearings/rears are like they said ,adjust the shoes in and wack them real good with hammer
Old 03-31-2008, 10:32 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: drum brake help
he has a 71, so we'll assume this is rear drums he's workin on.
If the drum is stuck on solid, then it is probably stuck on the center hub. you can spray some penitrating oil on there, but the best thing, is do just smack it hard with a hammer.
If you pull on the drum and it moves, but gets pulled back on... then your shoes need adjusted down and it'll slide right off.
Old 03-31-2008, 11:03 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: drum brake help
I just had to remove the front ones on my 68 GMC to check them.... You didn't say if you're removing the rear or front.. But as already mentioned, use a screwdriver to lift the adjuster arm if you have one and then with another screwdriver or adjusting tool loose the star nut.
On the pic below you have to turn the wheel opposite of the way the self adjusting lever turns it.
68gmsee is offline   Reply With Quote
Old 04-01-2008, 12:47 AM   #9
Irishpilot
Re: drum brake help
Thanks for all the info! It is a '71 so it's just the rears and i think it is the adjusting screw. If I pry, the drum flexes and then settles back on
Old 04-01-2008, 01:50 AM   #10
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: drum brake help
Coat the axle flange with Never-seize when you are done. It will save some trouble in getting the drum uff next time.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-01-2008, 02:06 AM   #11
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: drum brake help
Thats my trick too oldgold70c10. There are few things I love as much as fighting with drums on a "simple" brake job.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-01-2008, 07:32 AM   #12
Irishpilot
Re: drum brake help
Yeah, all I was trying to do was take off the drums and paint them since I have wheels that expose them...so much for simple!
Old 04-01-2008, 07:41 AM   #13
shifty
Questionable
shifty's Avatar
Re: drum brake help
i ran into the same issue with mine recently. i was amazed that simply taking a BFH and smacking 'fervently' between the lug nuts in a circular pattern half a dozen times broke it free - and this is what the Chiltons or Haynes manual suggested to break em loose.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
