Old 03-31-2008, 07:31 PM   #1
haysonj
haysonj's Avatar
Truck changes temp while cruising
Took the truck out for its first long trip towing the boat. It seems to run 10 to 15 degrees hotter while cruising at 55 then it does in stop and go traffic. Could this be a timing problem maybe to much vac advance or to little. I have 36 degrees total at idle. Pulls in 34 degrees at 2500. Thanks for any help
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-31-2008, 10:01 PM   #2
stonewall618
Just loves his truck.
stonewall618's Avatar
Re: Truck changes temp while cruising
im lost...
Gold 1969 c10 LWB--350 gm crate motor 30"muds on the back...with aluminum rims with black and red Chevy bowtie center caps that look awesome!
EAGLE SCOUT FTW!!!
stonewall618 is offline   Reply With Quote
Old 03-31-2008, 10:08 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
whats the temperature?
You sure it isn't caused by higher outside temps?
How much did the boat weaigh?
Any long hills you were climbing?
Old 03-31-2008, 10:17 PM   #4
haysonj
haysonj's Avatar
Temp goes from 180 to 195 gets hottest when on flat ground that's why I thought it could be the vac advance pulling in to much advance at cruise I just checked the number on my advance can and it has a total advance at 10 to12 hg of 22 degrees that's way to much I have 12 degrees initial 21 degrees mechanical and 22 vac at cruise that's a total of 55 degrees. I need a different vac can. This Dist came out of a 1975 corvette so maybe it had a big cam in it.
Old 03-31-2008, 10:22 PM   #5
cdowns
cdowns's Avatar
sounds like normal thermostat operation
Old 03-31-2008, 10:44 PM   #6
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
electric fan set-up?
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-31-2008, 11:13 PM   #7
haysonj
haysonj's Avatar
the fans come in at 180 and it can sit and idle all day and never go over 180 and you would think that going down the road it wouldnt need the fans. If I turn on the air conditioning the fans come on at 60 % and it would drop the temp by about 5 degrees also going up hill in second it would drop back to 180 or so. I'm sure it has something to do with timing
Old 03-31-2008, 11:46 PM   #8
LONGHAIR
I think you are a bit confused about the vacuum advance.....it gives you the most advance that it possibly can at idle, or when fully closing the throttle at speed. So you are only getting that if you are producing that much vacuum at cruise/part throttle. Do you have a vacuum guage that you can read while driving?
Several things effect the vacuum while driving:
the engine combination (ie cam, manifold,etc)
gear ratio
weight of vehicle and trailer
incline of hill
rate of acceleration
If you really are pulling that much vacuum, it could be causing some of the heat gain....but I don't see a problem with 195 while towing. Unless you are getting a ping/rattle/spark knock, I wouldn't worry about it.
LONGHAIR is offline   Reply With Quote
Old 03-31-2008, 11:46 PM   #9
72swb_327stroker_?
knuckle buster..
sounds normal to me
mine does the same at freeway speeds with fans at 100% duty
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 04-01-2008, 05:31 AM   #10
Boog
laying low
Boog's Avatar
I'm pretty sure that 383 would hammer itself to death if it was getting 55* advance. Put an advance dial timing light on it and run the rpm up to 25 to 2800 rpm and read just what total advance it is getting.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-01-2008, 06:11 AM   #11
Longhorn Man
I've never heard anyone complain about 195 degree temps before personally.
Old 04-01-2008, 04:28 PM   #12
haysonj
haysonj's Avatar
Here is a very interesting article posted by Alaskan in the tech FAQ section (Timing 101) and this is where I got my information. Chevys like 36* total advance at WOT but at cruise speed on level ground run best at 52*. This should be read by anyone trying to tune a Chevy engine. http://www.hotrodders.com/forum/dist...1-a-59033.html
Old 04-01-2008, 04:47 PM   #13
haysonj
haysonj's Avatar
I'm not really worried so much about the temp as I am the cause and of course the 8 MPG the truck is getting. My one ton with the same gears and a 350 motor gets 12 MPG towing the boat
Old 04-01-2008, 05:24 PM   #14
68gmsee
Active Member
68gmsee's Avatar
I've had a similar experience on couple of my vehicles. One turned out to be a slight leak in the head gasket and the other a collapsing lower radiator hose.
On the head gasket leak, hot exhaust gases were forced into the water jacket causing a rise in temp. This happened mostly at higher speeds. Problem was when the engine cooled off, everything checked out. Hope this is not your case but it wouldn't hurt to do a leak test if everything else checks out.
Hose collapsing only happened under extreme load and heat conditions. I guess wouldn't hurt to replace if it looks like it's an old one with the wire coil inside...
68gmsee is offline   Reply With Quote
Old 04-02-2008, 08:42 AM   #15
wzuke
wzuke's Avatar
Are you using a clutch type engine fan? If so check to see if it is functioning properly.
wzuke is offline   Reply With Quote
Old 04-02-2008, 02:54 PM   #16
Is this truck an automatic?It could be the trans/torque convertor heating things up pulling on the freeway due to minor (undetectable) slippage,inadequate cooling,or poor flow due to the need of a back-flush.Do you,by chance,run a trans temp guage?From my experience these trucks run steady low temp consistantly any way you run them.My GMC is doing pretty much the same thing.I`m suspecting my trans after going over the cooling system.It could be poor radiator flow.
On a truck I had I was experiencing climbing temps on the hiway.It`s a gradual climb all the way home.I could just make it to a certain exit before getting too high.Driving the old roads with curves,hills,and cool river valleys (letting off throttle and drifting) it could make it home.I ran it a couple weeks being really busy working sun-up to sun-down.I finally checked and it was the flex-fan all deteriorated to not much there from fatigued metal.So,the fan plays a big part in cooling,even at hiway speed with excellant air flow.
I hope this helps broaden your posibilities to look into.
Old 04-02-2008, 04:08 PM   #17
haysonj
haysonj's Avatar
Truck has rebuilt turbo 400 trans with custom built torque converter for towing matched to the engine. Has duel electric fans and two trans oil coolers. Others suggested it could not possibly have 55* of advance at cruise but it did. This motor pulls 22 HG of vac at 55 miles per hour. I've changed Vac cans and it now is at 51* of advance at 2500 RPM I need to take it out again with the boat to see if it helped any. Thanks to everyone for the help.
Old 04-03-2008, 06:50 AM   #18
Boog
laying low
Boog's Avatar
That's some good info. I've been enlightened.
Boog
primer is finer
Old 04-03-2008, 11:13 AM   #19
68350
68350's Avatar
a 4x4 will probably get 8 mpg, too, in case you're wondering. they definitely aren't gas savers!!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
