Old 03-31-2008, 10:23 PM   #1
usdabeef
electric fan advice
I am considering going to an electric fan system on my 72. I don't know much about them. I know there are some cheap ones out there, but I want to know what the best ones are. I currently have a single core radiator which i will be swapping out for a four-core. Any input on this would be appreciated.
usdabeef is offline   Reply With Quote
Old 04-01-2008, 12:06 AM   #2
msgross
msgross's Avatar
Re: electric fan advice
there is a thread were someone used a Mopar fan for a Jeep cherokee, fit perfectly into our shroud and only cost like $75 or so...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-01-2008, 05:15 AM   #3
Ace in the hole
I am going to use the jeep set up but it will be a few more months before I could tell you how well it works. From initial reports it works great unless you plan on towing a lot.
check it out here- http://67-72chevytrucks.com/vboard/s...d.php?t=254617
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 04-01-2008, 06:13 AM   #4
sandking
.....I am working on it.....
sandking's Avatar
If you want the best, get Spal fans and a tight fitting shroud.
sandking is offline   Reply With Quote
Old 04-01-2008, 08:28 AM   #5
Mudder
Mudder's Avatar
Wes at classic heartbeat sells a duel fan and shroud that is pretty straight forward for our trucks.
Mudder is offline   Reply With Quote
Old 04-01-2008, 02:31 PM   #6
vtblazer
vtblazer's Avatar
Found under 'electric fans' using the search function:
http://67-72chevytrucks.com/vboard/s...earchid=762131
vtblazer is offline   Reply With Quote
Old 04-01-2008, 04:26 PM   #7
msgross
msgross's Avatar
link didnt work...
vBulletin Message
Sorry - no matches. Please try some different terms.
The Garage:
Old 04-01-2008, 05:57 PM   #8
Mudder
Mudder's Avatar
That's weird it worked earlier.
try this: http://67-72chevytrucks.com/vboard/s...earchid=762275
Old 04-02-2008, 11:16 PM   #9
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Here's a link to a couple ideas:
http://67-72chevytrucks.com/vboard/s...d.php?t=282793
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 04-03-2008, 12:59 AM   #10
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Here is a link to ours. http://www.classicheartbeat.com/radi...&__related.htm
WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-03-2008, 02:46 AM   #11
70GMCer
70GMCer's Avatar
I'm using the Jeep fan. So far no problems. I have it running with a 180 degree tstat probe and a manual off/on switch under the dash in case the tstat ever fails. The fan fit is perfect in the stock shroud. Also I am using a 2 row radiator. Runs between 175-195 degrees on my 383 engine w/auto. All total, I have around $55 in this setup. I got the fan off Ebay for $25.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-03-2008, 06:17 AM   #12
wibilly
wibilly's Avatar
i saved a duel fan and shroud setup from a 80 or 90 somthing caddy sedan deville looks to be real close to being a bolt on deal. now to get started on the truck to see if it's as slick as it looks
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-03-2008, 02:57 PM   #13
70GMCer
70GMCer's Avatar
Keep in mine the amp draws on some of those fans are pretty high & your alternator might not be big enough. Just a thought...
1997 GMC Sierra Ext
1965 Mustang
Old 08-05-2008, 02:31 AM   #14
dazza
dazza's Avatar
so I received the Jeep fan today... quick question...
I might sound a bit ignorant here, but..
In the FAQ thread, everybody talks about the relay and the thermal switch. Are these really necessary? Can I not just hook it straight up to ignition power, running always when the truck is running? What benefit would it have kicking on and off?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 08-05-2008, 02:54 AM   #15
d10s69c10
Built 4 Speed
d10s69c10's Avatar
th relay is for running high amperage thru a low amperage switch and the thremal switch is kind of what it states kicks on at a cetain temp and shuts off at another..
i just went with a 30 amp switch and i run the fans when im not moving.. a bit of a pain for some but eases my mind when i drive.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 08-06-2008, 01:24 AM   #16
71 TopCat
PLAY HARD.....OR DONT PLAY!
71 TopCat's Avatar
My 454BB was running cool on the street but crazy hot while wheelin, using the GM 4 row radiator. I put a dual fan set up from FlexLite pulling and wired the A/C fan to the dual set up to push (3 fans total) made it better but still a bit hot while wheelin (not good for wheelin the Calif. dessert). finally broke bread and got a Griffin (2) 1 1/4 row radiator and it made a huge difference ! Back to what was said about the alternator. After the 3 fan set up at high RPM's the stock alternator was only putting out 10 volts at its best while running the A/C, then I turn on then radio with amplifier and it went down to 8-9 volts (not good having a dead batt. in the Calif. dessert) so I had my buddy install a 110 amp internal regulated alternator. now the voltage gauge barely drops from 12-14 volt's with everything on.
IF YOU DONT HURT..........YOU NOT TRYING HARD ENOUGH.
71 CST BLAZER 4X4, 1 TON, 496 STROKER/TH400, NP205, D44/14BOLT LOCKER, 35" BFG'S,...
68 C30 292 LB (POP'S BOUGHT IT BRAN NEW)
05 2500 4X4 DURAMAX CREWCAB
79 FLH HD 95CI EVO
:b69
Last edited by 71 TopCat; 08-06-2008 at 01:26 AM. Reason: forgot to mention "using the GM 4 row radiator"
71 TopCat is offline   Reply With Quote
Old 08-07-2008, 05:17 PM   #17
67mater
67mater's Avatar
The issue is that if the fans runs consatntly, the engine takes much longer to warm up. If it's always hot where you are amybe it's not a problem, but in Illinois, you want it thermo controlled.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 08-07-2008, 08:26 PM   #18
dazza
dazza's Avatar
Thanks 67mater... I'm in Cali so I don't really need the thermal hook-up. Would the relay be needed if I'm not going to use the thermal switch?
Old 08-08-2008, 09:54 AM   #19
LONGHAIR
Yes. It takes the load away from the switch itself. These fans are a big draw, the relay shortens the wiring run and saves the switch.
You might as well use the thermal switch though. There is no need to run the fans at highway speed....trying to turn it on/off by hand will get old pretty quickly. Why run them when you don't need to? It is just more taxing to the charging system.
LONGHAIR is offline   Reply With Quote
Old 08-08-2008, 03:03 PM   #20
dazza
dazza's Avatar
Thanks Longhair
