Old 04-01-2008, 04:28 AM   #1
dinotruck68
dinotruck68's Avatar
for sum reason my truck wont get out of forwheel drive...
my truck has been leakin pretty crazy for the last couple of days so i fixed it an got sum new oil in...this mornin i went an climbed sum hills by the canal in 4x4.. an now the truck wont shift bak into 2wheel drive i force it down an it just pops bak into 4hi ... is it the cases linkage? or could me drivin it around like a tard ,,, without oil for a while hav messed it up... its 68 k10 w/ a 465 an a t221.
dinotruck68 is offline   Reply With Quote
Old 04-01-2008, 05:09 PM   #2
1969K10
1969K10's Avatar
Re: for sum reason my truck wont get out of forwheel drive...
You probably have some bind in the gears. Try backing up a few feet and see what happens. also, I generaly had better luck going in or out of 4WD if I did it while moving slowly.
When I first got my truck with the old T-221, the shifter stuff was all loose and slopy, and it was a real PITA to shift. tightening up the bolts & putting in a few washers made a HUGE difference in how easily it shifted.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-01-2008, 07:47 PM   #3
Yukon Jack
Yukon Jack's Avatar
Keep an eye on your gear oil level or you will be like me - replacing your Rockwell due to bearing damage caused by low gear oil.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-02-2008, 06:57 AM   #4
dinotruck68
well i drove it to school today ...it was still stuck in 4hi.. an now sumthin else is goin on, my clutch isnt working at all.. the truck will only get into reverse.. unless i turn it on in 1st or 2nd gear. and its making an ugly clanking noise... now it barely even moves with out makin a bunch of noise an even a couple sparks from the clutch... im beginning to think the o'l t221 isnt any good anymore either the noise it makes doesnt sound good at all...
Old 04-02-2008, 09:27 PM   #5
1969K10
1969K10's Avatar
have you checked your motor mounts recently. as in loose, or broken...
Old 04-03-2008, 03:43 AM   #6
dinotruck68
no i havent... now that i think about it the T/case was missing 2 bolts... DANG an another one off a motor mount...
is this pretty bad??
forgive my im just barely learning about all of this technical stuff.
Old 04-03-2008, 07:14 PM   #7
1969K10
1969K10's Avatar
Sounds like replacing some bolts my eliminate some of your other problems.
