04-03-2008, 08:18 PM | #1 |
Junior Member
Bagged w/coys and pics *New pics*
Finally got it on the ground. Yes, my tires are on the wrong direction. Wheels are 18x8 and 20x10. 3" Drop spindles, RE7's on all four, 73+ disc front with glocks camaro rear disc setup. Front is sitting on fender wells and rear axle is on frame. I'm building a backhalf with 4 link canti setup and the fender wells are coming out! Front frame Z and body mount drop after my Classic Auto Air A/C install.
04-03-2008, 08:19 PM | #2 |
Junior Member
Re: Bagged w/coys and pics
04-03-2008, 08:42 PM | #3 |
Looking good. What size tires are you running? It looks like you have a good amount of sidewall which I like.
'73 C-30 3+3 Dually 454/TH400 '74 Fleetside 350/TH350 (SOLD) '69 Nova 350/TH350 (project FOR SALE) '63 Nova 305/TH350 3.73 posi (the wife's project) |
04-03-2008, 09:00 PM | #4 |
Weren't you in AZ not too long ago?
04-03-2008, 09:06 PM | #5 |
Junior Member
235/50-18's and 295/40-20's....Also, I went with Falken tires because I did not like the aggressive tread pattern the Toyo's have. I figured the Toyo's would take away from the nostalgic look of the wheels. The Falken's look really good but not sure about the quality. They were about the same price as the Toyo's.
Never been to AZ... Yes they are backards, better traction this way. Never been to AZ... Last edited by 68laydout; 04-03-2008 at 09:37 PM. |
04-03-2008, 11:32 PM | #6 |
That's wild. There's a board member that was from TX (DFW area IIRC) that moved to AZ. He was building a red/brown primered 68 using 18/20 Coys combo (and looking into a GEN III swap I think).
Where in the neighborhood are you?
04-03-2008, 11:47 PM | #7 |
Junior Member
Thats wild, but not me. I'm in Frisco.
04-04-2008, 02:46 AM | #8 |
Pretty dang close (but different ) . . ..... http://67-72chevytrucks.com/vboard/s...d.php?t=217668
04-04-2008, 03:55 AM | #9 |
Insert Title Here
yeah I thought it was that guy to when i opened it, had to look and see if this was an old thread..... truck looks great by the way
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
04-04-2008, 03:55 AM | #10 |
04-04-2008, 04:03 AM | #11 |
Looks good!
04-04-2008, 04:17 AM | #12 |
looks good got any aired up pics
nickle and dime |
04-04-2008, 04:27 AM | #13 |
Tot Roddin'
Love the bags, and wheel/tire combo... fits your truck well!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-04-2008, 05:02 AM | #14 |
looks great , appearently theres more of us in DFW than I thought.
04-04-2008, 05:33 AM | #15 |
Indeed - Looks great!! I'm in your neck of the woods too....we need to get all of the N. Tx guys together some time. Mine is coming along really well right now....working my 70' SWB towards being a slammed/tubbed "farm truck" with a really pissed-off SBC....should be rolling by June or so.
72' LWB Cheyenne 73' Camaro Z28/RS 70' Chevelle RagTop 00=ss=00 |
04-04-2008, 05:35 AM | #16 |
BTW - I've been looking a Coys as an alternative set too....can fit a huge tire on back of mine, but was wondering about the stagger. Are the 20's even an option, or just too big on front?
04-04-2008, 05:59 AM | #17 |
what backspace did you use on the rear of the truck
04-04-2008, 06:07 AM | #18 |
Im in AZ (moved here from TX). I had to go out to the garage and make sure the truck as still there!!!!!
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. Last edited by 68GenIII; 04-04-2008 at 06:09 AM. |
04-04-2008, 06:09 AM | #19 |
Nice truck and great stance! I just ordered my RE-7s and am getting ready to order the same size Coys wheels. I'd be curious to hear about your experience with Coys in terms of delivery as I keep hearing different stories. What back space did you go with?
Can we get some pics of the truck out of the garage? I'd like to get a good look at that front tire as I'm not sure what size I'm going to run. You say the axle is on the frame - are you running a C - notch? Any pics of panhard and shock set-up? If you've driven the truck, I'd be curious to get your impression of the ride. Sorry for all the questions; it's just that you and I will have the same set-up until you take the plunge and go "all-in". Keep us posted - truck looks good! |
04-04-2008, 06:13 AM | #20 |
18/20 stagger looks great. Truck looks awsome. 18/20 is the way I went.
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
04-04-2008, 06:15 AM | #21 |
Junior Member
20's will work fine up front, I just wanted the staggard look with these specific wheels. I personally would go bigger if running billets or forgelines, but with these wheels I like the 18/20 combo. I almost bought billets but decided A/C was more important to me.
The rears are 5.5" BS which is not what I wanted but was all they had in stock. I'm going to run spacers in the rear just not sure on the size yet. |
04-04-2008, 07:11 AM | #22 |
What size tires are you running front and rear?
04-04-2008, 07:56 AM | #23 |
That's the same BS I heard. No spacer for me though . . ....
04-04-2008, 06:18 PM | #24 |
Junior Member
-DA68
Thanks. Call Coys directly and you will have them in 2-3 weeks if they've got what you want in stock. I called and asked them about ET style lugs so I could run spacers in the rear. The guy said no worries and sent me some ET lugs. 4.5" BS front, and 5.5" back. I will get some pics of the front tires. I thought they were going to be a little too skinny, but I like them. They look really good on the wheel and truck. The axle is just resting on the bottom of the frame in the pics. No c-notch. I'm building a backhalf so I can lay frame. I'm running custom brake lines right now so I can't roll it out just yet. I will air it up a little and take it for a spin this weekend after I get the brake lines done. I'm going to temporarly run the shortest stock replacement KYB gas-adjust shocks from CPP front and rear. Stock panhard right now, which will get replaced with a triangulated 4 link. |
04-04-2008, 06:22 PM | #25 | |
Junior Member
Look at the last pic in the post, it has all the tire size info. Last edited by 68laydout; 04-04-2008 at 06:28 PM. |
