Old 04-04-2008, 08:25 PM   #26
Rooster's82
Rooster's82's Avatar
Re: MPG. I need some more Brains to help me out.
Originally Posted by babyJay View Post
You would need to eliminate the factory shroud. It's not needed.
but that fan has enough power to keep my engine cool? Would i have to make a new shroud or just pop the new one in there with no shroud?
JG
If you can't find it at the junk yard you don't need it.
Rooster's82 is offline   Reply With Quote
Old 04-04-2008, 09:30 PM   #27
babyJay
Arrived on a Pale Horse
babyJay's Avatar
http://www.electricfanengineering.com/over-the.htm Has some info you might find useful.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-05-2008, 03:23 AM   #28
piecesparts
Parts and more parts
piecesparts's Avatar
Originally Posted by Rooster's82 View Post
how much better is a duel fan setup to a single "universal" electric fan that fits in the factory shroud? Will it draw enough air? For example:http://www.jcwhitney.com/autoparts/P...001645/c-10101
The setup that I purchased and used on both of my trucks is the SPAL dual 11" fans with their own shrouds. Summit Racing has them listed under the "BeCool" fans in their catalog. I spent some time with the guys from "BeCool" a few years ago and learned how SPAL calculates their airflow and how they compared to other brands. I collaborated this with the people that own the Flex-a-Lite company, also met them on a little cruise trip. The SPAL people do their flowrates in a "DYNAMIC" test and the others seem to do theirs in a "STATIC" format. The dynamic being with a pressure behind the fan (such as you would have under your hood) and the static being tested with just a standard atmospheric pressure behind the fan. My two fans flow 2800 scfm with a backpressure on them and it works real well.
I mounted my fans up close to my radiators, by using aluminum strapping from my local hardware store and the fans stand up to just about anything that I do. The extra room in the engine bay is also a big plus. (the stock fan shroud is tossed). I control them so that only one turns on, unless the temps go high, then the second cycles on to support the first. I have yet to get to the second fan and use it.
Old 04-05-2008, 04:01 PM   #29
Rooster's82
Rock and roll.
JG
Old 04-05-2008, 04:41 PM   #30
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Here's a link on how to install a late-model jeep fan into your factory shroud. This is for install on a 67-72, but the shroud openings should be similar. The fan itself only runs about $70. In a follow up, one member reported gaining 3mpg with a 250L6! This is defenetly on my to-do list!
http://67-72chevytrucks.com/vboard/s...d.php?t=254617
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
