Old 04-04-2008, 08:46 PM   #1
tjluke36
Brake Lock
Hello all
I just bought a summit brake lock. and want to install on my 1978 4x4 to use at the drag strip.I have to lines coming of the master cylinder.going to the proportioning valve.one line looks like 1/4 and the other 3/16.the 3/16 looks like the front disc brakes and the 1/4 go to the back.can I connect the Brake lock valve at the master cylinder ? on the 3/16 line? The Tec person at summit said I should take one line off at the proportioning valve going to the front brakes and put the brake valve in with only one side.I don't like the sound of only one wheel holding at the line.
has anyone done this I am sure there is ,Thanks
Tjluke36
tjluke36 is offline   Reply With Quote
Old 04-05-2008, 12:22 PM   #2
oldspowered67C10
Re: Brake Lock
Im not sure I understand the whole 1 wheel thing. If the porportioning valve only has 2 lines coming out of it then if you put the line lock in one of the lines then youd be locking 2 brakes. Im not sure if yours is like mine but on mine the front brake line comes out of the porportioning valve and then runs down to the frame to a junction where the line tees into two lines, one for each wheel. As long as you put the line lock in between the porportioning valve and the tee then youd lock both front brakes.
oldspowered67C10 is offline   Reply With Quote
Old 04-06-2008, 06:44 AM   #3
tjluke36
Re: Brake Lock
I went on Hotrod web site they had pictures of how to connect it up so that is what I have done haven't finish it yet will let you know if it works .Thanks
Tom
Old 04-06-2008, 06:00 PM   #4
Shane
Shane's Avatar
Re: Brake Lock
why would you take a 4x4 to the drag strip?
Shane is offline   Reply With Quote
Old 04-06-2008, 08:51 PM   #5
tjluke36
Smile Re: Brake Lock
we have
Truck drags at woodburn drag strip every summer,and that is all I have just for fun.
Tom
