Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-04-2008, 10:56 PM   #1
chevy72blu
chevy72blu's Avatar
Narrowing the rear end
I am running a 14.5" wide tire in the rear on a 10" wheel (dont have the BS #'s with me, but im sure I can find them), and a GM 8 7/8" 12 bolt. The rear is out of a 73-87 3/4ton (I believe). I have already gone through it with gears/LSD.
My current set up works fine- but my tires stick out about an inch and a half, maybe 2" from the lip of the fender.
What all is involved in narrowing the rear? Doesn't seem like it would be too hard to pull the drums, remove my axles, throw the thing on a long steel band saw (my dad's company has one),make a jig to hold it level, section out 1.5-2" on each side, re-weld, and gusset it. I would make the cuts based on available upgraded axle lengths, and then put the thing back together. Of course I would have to get it 100% strait before re-welding it- I imagine this is where the danger is. If I can, I'd like to not have to mess with my fender wells, and I think I have enough room to do it. If not, Ill buy some aftermarket steel tubs and weld them in, mine are pretty dented up anyway.
I have to pull the rear out anyway when I start making my trailing arm setup.
Where is the best place to make the cuts? Inside, middle or outside?
Thanks for the help guys!
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-04-2008, 11:11 PM   #2
collin86
Re: Narrowing the rear end
if you are only sticking out 2 inches or so on either side i would not mess with narrowing it and just get different backspace wheels (2" more on each side)
if you are set on narrowing you are on the right track. you just need to get it in a jig to make sure everything is perfect and straight. as far as axels go you can call stange or moser or yukon and tell them your spline count and the length you need and they will make them for you. so you can narrow as much as you want.
1986 swb...soon to be some weird pro touring look..but better
92 jeep cherokee.... crawler
collin86 is offline   Reply With Quote
Old 04-04-2008, 11:31 PM   #3
whatnow123
whatnow123's Avatar
Have you checked the difference in width on for the 67-70 rear ends? That might put you in the ball park. I know they are about 1.5 inches narrower than the 71/72 and it might even be more on the later rear ends. That way you woudn't have to narrow anything, all your "inner'ds" will swap right over and it would already be set up for trailing arms.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 04-05-2008, 01:09 AM   #4
chevy72blu
chevy72blu's Avatar
Thats a good idea, and would keep me from having to buy a few parts. Ill take some measurements and look into how much I could get out of the back spacing, sounds like thats what I should check out first. My dad bought the wheels/slicks for me for my birthday a few years back, and im sure he just went with a safe BS.
Im wondering if I should wait to see how well I can hook the thing up my new suspension before I do this anyway. If im still spinning, I know ill need to mini-tub and go to a bigger tire.
Thanks for the help!
RIP EastSideLowLife
Old 04-05-2008, 02:03 AM   #5
69trk
69trk's Avatar
I'm running a 14.5 qtp with a 4.75in. bs. on some centerline wheels that are only 9.5" wide. They don't stick out at all. I wish my rims were 12in. wide but i can't find anybody that make them in 16". I did have to widden the wheel tubs, i just went to salvage yard and found some and spliced 2" into mine. If i can find some 16x12's i'm going to go ahead and get 5" of backspacing.
69trk is offline   Reply With Quote
