Old 04-05-2008, 02:48 AM   #1
Iron-Butt
454 club
Iron-Butt's Avatar
air ride strong arms.
Do the air ride strong arms have brackets or holes to use the front sway bar. The sway bar I have is 1 1/4 inches.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 04-05-2008, 06:06 AM   #2
billydonn
Council of the Elders
billydonn's Avatar
Re: air ride strong arms.
Good question. I have looked at them on the internet and it looks like they are designed to fit a special sway bar made by Air Ride. I don't know for sure though. Someone else, please chime in!
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 04-05-2008, 07:11 AM   #3
jasonb72
PorterBuilt Man Crush
They are made to use a sway bar with end links, the stock bar will not work.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 04-11-2008, 09:45 AM   #4
Iron-Butt
454 club
Iron-Butt's Avatar
does any make a lower control tublar arm to work with the stock bar?
David
Old 04-11-2008, 04:24 PM   #5
billydonn
billydonn's Avatar
I think Performance Online sells them... but I'm just judging by a picture I was looking at the other day. You would need to verify that with them. I would think there are others too.
66 C-10 Stepside
Tremec TKO-600
Old 04-12-2008, 07:33 AM   #6
1963chevyshort
New Member
1963chevyshort's Avatar
Well i bought both and if you are going to use Nathan's setup you will have to use the air ride setup. The air ride control arms do have holes for the performance sway bar but i do not think it will accept the orginal. It will lower your truck if you use airbags of course. If not it will lower it a little less than stock. Both setups are good from airride and performance online but they will not work if you mis match by getting POL uppers and airride lower. If you look at my setup you will see I tried both and see what happens. Hope this helps.
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
Old 10-02-2008, 04:03 PM   #7
65shortbox
65shortbox's Avatar
Hey 63chevyshort, how did you get the front to lay so low? Did you use a different crossmember? And what about the rear, just a regular c-notch? I'm thinking about bagging my truck also but I don't want to sacrifice ride quality too much. Any advice would help...
65shortbox is offline   Reply With Quote
Old 10-03-2008, 12:17 AM   #8
vin63
It's Better With Nitro
vin63's Avatar
The CPP lower control arms worked with my narrower stock sway bar. I'm switching over to the Air Ride Strong Arms because they're not so harsh riding with the rubber bushings. I had to use the wider sway bar for the Strong Arms.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-03-2008, 01:21 PM   #9
Tony@AirRideTech
Junior Member
Our arms will not work with the factory sway bar. The problem with the factory sway bar is the style of the bar and clam shell bracket itself. Just as soon as you alter the ride height, your sway bar is already starting to bind out in the clam shell. Ours changes it over to the new Posi Link end links.
Tony@AirRideTech is offline   Reply With Quote
Old 10-03-2008, 02:04 PM   #10
c10addict
c10addict's Avatar
Call Addco... I had them make one for my 64 to work at the dropmember and ART strong arms.. Its a great product and a great company to deal with..
Linky
http://www.addco.net/
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 10-04-2008, 03:34 PM   #11
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Hey C-10,
Think they could do the same for a '72 frame? It's pretty much the same as your 64 right? how about cost?
TIA,
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 10-04-2008, 11:11 PM   #12
c10addict
c10addict's Avatar
Originally Posted by RunninLo View Post
Hey C-10,
TIA,
Josh
Yep its the same bar... I ordered it for a 67 to 72... $138.00
Old 10-06-2008, 02:59 PM   #13
1963chevyshort
New Member
65shortbox the kit is for Nathan at Porterbuilt street rods. That drop is with is cross member and regular stock 72 chevy truck spindles. The rear is air ride strongarm kit with a regular C notch and a small bump stop. I wanted the same as you i wanted to keep my bed and did not want to start cutting into things.
Anthony
