Old 04-05-2008, 02:59 AM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Changing from 6 Lug to 5 Lug. Will it fit?
I'm interested in changing the rear 6 lug axle to a 5 lug axle. The 6 lug is from a 1969 GMC Truck (originally leafs but now coils) and the 5 lug is from a 1967 Chevy Truck with coils.
Will this 5 lug rear end fit on my 69? Or is it....Too Short. Too long. OR Just Right. Thanks, Guys and Gals for your input. Harry
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 04-05-2008, 03:26 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Changing from 6 Lug to 5 Lug. Will it fit?
The 5 lug is from a 67? If so it isn't factory.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-05-2008, 03:59 AM   #3
myoldchevytruck
True. What is the best way to check for fit? Where do I measure from on my 6 lug and then how do I compare the two? Thanks, Harry
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 04-05-2008, 06:32 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Are you just swapping the whole rearend... or axle shafts?
The former will work, the latter will not.
Old 04-05-2008, 06:51 AM   #5
myoldchevytruck
Andy, thinking about the whole rear end. Existing 6 lug rear end is from the leaf spring setup. As stated, I've swapped over to trailing arms.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 04-05-2008, 06:52 AM   #6
prostreet1967
prostreet1967's Avatar
just swap axles
prostreet1967 is offline   Reply With Quote
Old 04-05-2008, 06:52 AM   #7
prostreet1967
o now i c
Old 04-05-2008, 06:53 PM   #8
shifty
Questionable
shifty's Avatar
Measure the length of both axles from the square 4-bolt provision to square 4-bolt provision. If they are the same, just swap the axles. If one of them is between 1"-2" longer, then the axles are probably going to each by ~1/4" too long.
I have a 5-lug '71 (leaf spring) rear up here with a POSI (G80) rear if you need it. I'd need to re-install the axles into the tube, but it's not that hard to tend to. It's currently gathering dust in the corner.
(You'd need to pick it up, though)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
