Old 04-07-2008, 06:38 AM   #1
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Drag and Destroy rebuild
Well, the 62 is in a thousand pieces in the driveway. finally got some help with the mess of a chevy to tear it down and rebuild the cobbled up mess the PO installed. heres a few pics of what we have done today. hoping to get the rear end glued back together and rolling again on sunday.
kdrodworks316 is offline   Reply With Quote
Old 04-07-2008, 04:05 PM   #2
slammed1966chevy
slammed1966chevy's Avatar
Re: Drag and Destroy rebuild
Nice cant wait to see it !
When in doubt drop it !
slammed1966chevy is offline   Reply With Quote
Old 04-07-2008, 04:08 PM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Cool man....although I never seen a rearend narrowed that way.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-07-2008, 09:01 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
This shows it was posted today? It was 85* yesterday........whats that white stuff??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-08-2008, 02:21 AM   #5
kdrodworks316
KOFFIN DRAGGER
the rear end is back in, I would post the pics, but they are to big. thanks to Todd for all his help!
Old 04-08-2008, 02:29 AM   #6
kdrodworks316
KOFFIN DRAGGER
here ya go! the white stuff is what we can snow in these parts. It was only 40 degrees and snowing off and on while we fix this pile of chevy.
Old 04-08-2008, 02:39 AM   #7
slammed1966chevy
So were are your bags going to be ?
Old 04-08-2008, 04:39 AM   #8
kdrodworks316
KOFFIN DRAGGER
bags will be inside the frame over the axle. getting the brackets broke in the morning and hope to have them in by the afternoon. I build my own brackets, but have to have a shop break them due to lack of a press break.
Old 04-08-2008, 04:56 AM   #9
joe231
joe231's Avatar
looking good! you have any before shots of the suspension?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 04-08-2008, 05:52 AM   #10
greg64
greg64's Avatar
Looking good KD! What type of axle is that? I'm having trouble identifying it.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-08-2008, 07:53 PM   #11
kdrodworks316
KOFFIN DRAGGER
I dont have any before shots, but a description is in order. factory trailing arms removed from factory location, run strait back parallel to each other and welded together with a piece of pipe. then a cross pipe welded from left rear to right front. u-bolts welded to the rearend with enough rod to build a spaceshuttle. it was welded so good, my 3 pound sledge had no trouble removing it. the lower bag mounts spent most of there life driving a water pump on a SBC. the shocks were welded to a piece of 3" channel under the c-notch. the trac bar was welded to the end of the right trailing arm and to the left side of the c-notch. again the 3 pounder had no trouble removeing the chicken s*** mess the were trusting enough to drive down the interstate. the drive shaft is nearly cut in half from rubbing on the x member, and theres a hole in it. here some pics of what I removed.
Old 04-08-2008, 07:58 PM   #12
kdrodworks316
KOFFIN DRAGGER
heres some more pics. the last 2 are the new upper bag mounts and shock mount that I designed and cut on the CNC plasma.
Old 04-08-2008, 08:59 PM   #13
joe231
joe231's Avatar
WOW! what a mess that was!!
you make those bag/shock mounts to sell?
pm me with some info on pricing and shipping to zip 73071 if ya do
CHEVY ONLY
Old 04-08-2008, 09:02 PM   #14
kdrodworks316
KOFFIN DRAGGER
PM sent
Old 04-08-2008, 09:31 PM   #15
jchav62
1962 C-10
jchav62's Avatar
Looking good!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-08-2008, 09:53 PM   #16
62 short step
62 short step's Avatar
Looks good!
62 short step is offline   Reply With Quote
Old 04-09-2008, 03:08 AM   #17
greg64
greg64's Avatar
Wow, I wouldn't trust that original pile of chicken sh1t to hold anything! What a mess.
Greg
Old 04-09-2008, 03:46 AM   #18
slammed1966chevy
Wow that was not a safe setup !
Old 04-09-2008, 04:45 AM   #19
kdrodworks316
KOFFIN DRAGGER
now you guys know why I complain about the PO's craftsmanship on this jewel. unsafe at any speed.
Old 04-09-2008, 05:32 AM   #20
1963chevyshort
New Member
1963chevyshort's Avatar
Looks good keeep us posted
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
Old 04-09-2008, 09:34 PM   #21
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Holy sheisse man!!!! Now I see why you won't drive her up here!!!
Imperial Kustom is offline   Reply With Quote
Old 04-10-2008, 12:15 AM   #22
kdrodworks316
KOFFIN DRAGGER
you thought I was kidding, didnt ya. she will be on her feet by the end of the week, then we finish the new electrical system, replumb the brakes and fuel system, install the fuel tank. lower the engine back to stock, and install the T5 trans. then I can pull the cab and replace EVERYTHING from the door handles down because of rust or a runaway sawzall. just wait till you guys see the interior. this truck should win rebuild of the year!
Old 04-10-2008, 01:34 AM   #23
L0WRIDE
L0WRIDE's Avatar
Nice Work!!
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 04-10-2008, 01:41 AM   #24
protrash64
protrash64's Avatar
Good thing the PO never ran over a 3# sledge!!!!! Nice work on the reconstruction.
Old 04-10-2008, 05:57 AM   #25
kdrodworks316
KOFFIN DRAGGER
got the upper bag mounts and shock mounts in today. heres some shots of the progress and the butchered interior.
