Old 04-07-2008, 06:54 AM   #1
chrislehr
Engine n00b
chrislehr's Avatar
ECE 2/4 premium installed *crappy pics*
Finally got er done. Took me almost 8 hours (3+ of that was fighting those rivets off) working alone..
Not hard, just time consuming and a PITA in a dirt driveway. Managed to only draw blood once and not hurt myself too much either!
chrislehr is offline   Reply With Quote
Old 04-07-2008, 07:46 AM   #2
ed2552
ed2552's Avatar
Re: ECE 2/4 premium installed *crappy pics*
should've gone w/ a 4/6 or a 3.5/6 get it lower and level(er)
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-07-2008, 07:49 AM   #3
see ten
WTB this ad
see ten's Avatar
Looks good bro! Now take that 2nd pic and add it to the "night shots" thread!
see ten is offline   Reply With Quote
Old 04-07-2008, 04:41 PM   #4
Boog
laying low
Boog's Avatar
Ya know. I look at those caps and I picture a 66 and know they belong on a 66 but on yours they are growing on me. It's different. Like TT2's are great and all but are so common anymore it makes painted wheels look that much better. IMO
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-07-2008, 05:37 PM   #5
chrislehr
Engine n00b
chrislehr's Avatar
Better pics:
Old 04-07-2008, 05:45 PM   #6
c10crazy
Like a Rock!
c10crazy's Avatar
Looks good!. How hard was it to mount the shock relocators???
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 04-07-2008, 05:49 PM   #7
chrislehr
Engine n00b
chrislehr's Avatar
Mounting them was simple.
Removing the stock ones... Friggin 3 hours.
4 rivets... I had an air hammer and a cutting disc, too. Apparently my 90psi 20k rpm stuff was weaksauce compared to 1970 engineering...
Old 04-07-2008, 05:56 PM   #8
Boog
laying low
Boog's Avatar
Those new springs may settle down a wee bit after a few hundred miles. It may be just me but it looks a little bit lower in the rear than the front. I bet it still rides good though.
Boog
primer is finer
Old 04-07-2008, 06:27 PM   #9
see ten
WTB this ad
see ten's Avatar
You're not done yet! Get your wrenches back out and turn those upper shock relocaters around. It shouldn't take but a few minutes to swap em around, you've already done the hard part. The part where the shock goes through should be towards the back of the truck. The way they are now you're shocks are a bit too horizontal to be very effective.
Old 04-07-2008, 06:34 PM   #10
chrislehr
Engine n00b
chrislehr's Avatar
Yea, it does a tad... I am thinking a few days sitting should help...
Old 04-07-2008, 06:36 PM   #11
chrislehr
Engine n00b
chrislehr's Avatar
Hmmm, instructions said the longer hole (the slot) on the mounts faces the rear of the truck... I re-read that thing like 5 times... How the HECK did you get the bottom mounts nut out? I couldnt get that for the life of me.
Old 04-07-2008, 07:31 PM   #12
Gray Ghost
Gray Ghost's Avatar
I helped a friend remove a few rivets and they are tough. We got a sawzall in there for a few but the rest had to be torched/ground off.
That 2/4 drop is a very nice stance for your truck. Going any further wouldn't look good. I really don't like the ground scaper look any vehicle, especially a truck....always makes me wonder why anyone would do that.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 04-07-2008, 08:00 PM   #13
see ten
WTB this ad
see ten's Avatar
http://www.earlyclassic.com/tech.asp...0Big%20Ship2-3
Pic 14 shows the upper bracket with the hole for the shock towards the back of the truck. I'm not sure what you're refering to about removing a nut from the lower bracket? Elaborate a bit for me and I'll do all I can to help you out.
This one might show it a bit better.
http://www.earlyclassic.com/tech.asp...et%20Rolling-2
Old 04-08-2008, 02:14 AM   #14
northerngmc
northerngmc's Avatar
Does it ride better?
How does it handle?
Looks great.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 04-08-2008, 03:55 AM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice install the truck looks great!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-08-2008, 04:13 AM   #16
70c10
67-72 Addict!
70c10's Avatar
see ten is correct. Your lower brackets look fine. Just unbolt your upper brackets and rotate them the opposite way and your shock will become more vertical
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-08-2008, 04:18 AM   #17
chrislehr
Engine n00b
chrislehr's Avatar
heh - I never got around to it today. Not really hurting anything sitting there.. I can swap that with suspension loaded, too right?
Old 04-08-2008, 04:58 AM   #18
see ten
WTB this ad
see ten's Avatar
You shouldn't have a problem. Just unbolt the shock and you're gold!
Old 04-08-2008, 06:51 AM   #19
496stroker1
looks good. im having trouble figuring out what kinda drop i want, thinkin 5 inch coil drop in the rear and get the coils cut in front for now, later getting some drop spindles and disc's. how does it ride? bit stiffer than before?
496stroker1 is offline   Reply With Quote
Old 04-08-2008, 04:03 PM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
Didn't see it mentioned anywhere.... did you use the drop spindles or springs up front?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-08-2008, 04:16 PM   #21
chrislehr
Engine n00b
chrislehr's Avatar
springs only..
ride is very nice. A lot better road handling and bump recovery.. No longer feels like shattering panes of glass on bad bumps...
truck has less rattles now too thanks to this
Old 04-08-2008, 06:49 PM   #22
Chevyholic
Will it run today?
Chevyholic's Avatar
Looks great! I'm getting ready to place my order on the 2/4 premium drop as well. In hind sight, would you approach the rivets differently? What did you find as the most effective way of getting them off?
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 04-08-2008, 10:48 PM   #23
chrislehr
Engine n00b
chrislehr's Avatar
If I had drill bits made for metal, it would have been easier. Also, drilling/cutting/grinding while on your back SUCKS. I have a burn mark on my face from a hit piece of metal hitting me.
Old 04-08-2008, 11:13 PM   #24
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Glad you got it done without too much pain. It looks good!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
