Old 04-11-2008, 12:12 AM   #1
chevy72blu
chevy72blu's Avatar
rebuilding hydroboost M/C? (pics)
I picked up a complete hydroboost system out of a 80's diesel suburban with the pump and M/C.
Sorry for the crappy cell phone pic:
I paid 75 bucks for it. My question is, how can I tell if the MC is still in operable condition? If it isnt, is there a way to rebuild them? Hopefully I wasnt overzealous in picking this up - it was a christmas present from my folks =P
I am going to hydroboost to correct this:
The PB booster is just barely above the driver side valve cover (this is what happeneds when you use 73+ SBC frame towers on a 72). I have since bought the correct 72 only towers which will help a lot, but I still want to install the hydroboost set up.
I appreciate the help!
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-11-2008, 12:31 AM   #2
chevy72blu
chevy72blu's Avatar
Re: rebuilding hydroboost M/C? (pics)
Few more pics of the unit..
Btw: I always though the H/B PS pumps had a much larger resivoir - my stock BBC PS bracket is the right width. Still havent attempted to bolt it up to see if it needs any modification for the lines though.
As for the rod/pedal connection, I have read that 8 1/2" from the firewall is correct. Seems like a cinch to use a turnbuckle type female/female connecter with a rod and eyelet to get the right length.
RIP EastSideLowLife
Old 04-11-2008, 06:39 AM   #3
chevy72blu
chevy72blu's Avatar
Bump
RIP EastSideLowLife
Old 04-11-2008, 07:00 AM   #4
svgould
Active Member
svgould's Avatar
Go to hydratechbraking.com....they have a forum that helped me out when I was looking into the hydraboost systems!
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 04-11-2008, 08:09 AM   #5
chevy72blu
chevy72blu's Avatar
I looked over it and found some threads that will be useful, but they dont seem to keen on helping those who are doing a DIY install, as it is a corporate forum intended to help those who have bought/are buying their products
RIP EastSideLowLife
Old 04-11-2008, 09:32 AM   #6
svgould
Active Member
svgould's Avatar
Maybe it has changed......I haven't been on their in a few years, but they used to be very helpful to everybody. Sorry!!
1971 SWB SOLD
  • 4" rear springs
Old 04-12-2008, 01:07 AM   #7
Wrenchbender Ret
The Hydroboost is a rugged unit. They seldom give trouble except sometimes they leak. The master cyl part is easy to replace & is reasonably priced as a reman. If you decide to go into the hydro unit get good directions. There is some sort of reserve pressure in them that can cause serious injury.
Wrenchbender Ret is offline   Reply With Quote
Old 04-12-2008, 02:19 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can use the master you currently have on your truck.
Just make sure that the depth for the push rod is the same or close enough to adjust it correctly.
This may help with specs and part numbers. http://www.thehollisterroadcompany.com/hydroboost.html
There is also a write up on this site about the swap.
