Old 01-27-2003, 02:34 AM   #1
ironwood
$640 truck// doesn't run
74-C20 tranny crossmember
I have a problem with my tranny crossmember being in the way of the rear tranny pan bolts. Is this because it is a 3/4 ton? I have owned a '79 blazer 4x4 (was stolen )and I don't remember that cross member being in the way. Oh by the way my 74 is a 2wd. Any help? maybe one of you guys could crawl under your 1/2 ton trucks to see if you can get to your rear bolts
ironwood is offline   Reply With Quote
Old 01-27-2003, 02:35 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Same here for my 700R4. I can't get to the back four bolts.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-27-2003, 02:39 AM   #3
ironwood
So I guess the changing of the tranny fluid and filter is a weekend job when you can unbolt the crossmember and get to them ? What have you found to be the easiest way to change the filter/tranyy fluid?
Old 01-27-2003, 02:56 AM   #4
rustedchevy
undo the tranny mount and jeck up tranny back end and block of wood under it
rustedchevy is offline   Reply With Quote
Old 01-27-2003, 03:21 AM   #5
ironwood
So your saying I don't have to unbolt the crossmember from the frame? I can get a wrench on the bolt over the crossmember?
74 C-20 LWB
camper special
stock350/350
53 Chevy 1/2 ton- in California, where the rust is not. Ready for some LOVE!!!
Old 01-27-2003, 06:40 AM   #6
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
i went through this on my 74 1/2 ton.to get to the back bolts i needed to jack the tranny off of the crossmember,used a wobbly extension to get to the bolts then lower it back down and the rest were easy to get to.its really not that hard to do.i thought it would be but it proved differently.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 01-27-2003, 06:18 PM   #7
ironwood
Thanks for the help.
