Old 04-13-2008, 04:04 AM   #1
jorgensensc
jorgensensc's Avatar
Spindles rub. Can't find answer.
Hey all, I just finished putting on 2.5 drop spindles from Bell tech on the '68. i have a 73-87 front crossmember with disc brakes. I am running 15 x 8 truck ralleys. The problem I have is the lower control arm wants to rub on the inside of the wheel. I know this has been discussed before, but I tried a search and can't seem to find the answer. Should I use a spacer or just grind off part of the bottom edge of the lower control arm? It won't take much too clear the wheel. It is just enough to stop rotation though. Any advice is always appreciated!!
Thanks,
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-13-2008, 04:32 AM   #2
corn
Re: Spindles rub. Can't find answer.
Get your grinder out & trim the edge down on the LCA. It only takes about 5 minutes to do.
corn is offline   Reply With Quote
Old 04-13-2008, 04:33 AM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
I think grinding a bit off of the lca will work. mine spindles rubbed the wheel weights (mounted inside) of my Corvette rallyes. I ground the lca a tad bit and it took care of it. nice.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
