Old 04-15-2008, 02:02 AM   #1
Longhorn Paul
Mine's longer
Left me stranded, started, died again.
After a few months of problem free ownership on the way home my 69 started rough idling and then just died. Right in the middle of a busy road. Wouldn't turn over. Nothing. Got under the hood, moved a couple wires, nothing. Called for a tow. Tried again. Got the starter to fire. She coughed to life, got her to the mechanic.
Tigthend a few wires, started & stopped her 4 times. No issues. Left the mechanic... 800 yards down the road she just died - engine just quit. Would not restart. Turned over fine, but wouldn't start. Took the gas cap off (vapor lock?). Didn't help. Tried starter fluid: fire for a second or two and die. Seems like she's starved for fuel.
Suggestions? 396 motor.
Longhorn Paul is offline   Reply With Quote
Old 04-15-2008, 02:12 AM   #2
Billla
Billla's Avatar
Re: Left me stranded, started, died again.
Well, those are the places to start - fuel and spark.
Billla is offline   Reply With Quote
Old 04-15-2008, 02:41 AM   #3
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Just trade me your 396 for my perfectly running 350. That should get you goin!
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 04-15-2008, 02:48 AM   #4
2nd_wnd
2nd_wnd's Avatar
mine was doing that a couple weeks ago. after looking ti over I found that my fuel line from pump to carb was collapsing when engine got up to temp. Always a good place to start
72 LWB
2nd_wnd is offline   Reply With Quote
Old 04-15-2008, 03:09 AM   #5
Shyguy
Junior Member
Shyguy's Avatar
Mine was doing the same thing so I ended up replacing all the rubber fuel line which included the one underneath just below tank.
Also you might check the fuel filter. If it is a Q-jet it is where the fuel line screws into the carb.
Danny
Shyguy is offline   Reply With Quote
Old 04-15-2008, 03:53 AM   #6
Sounds like it`s out of fuel,dirt in line,collapsed line.,or bad fuel pump.
Old 04-15-2008, 04:54 AM   #7
Premium72
Premium72's Avatar
check your fuel line. i had some issue with this and it was sumthing with the line. i took the line off at the carb pointed the hose towards the ground turn the engine over for a bit(pumping sum gas out and what ever else). then pourd some fresh gas str8 in the carb and let it run till it died, to insure it was totally cleared out. replaced the line, been good ever since. good luck.
Premium72 is offline   Reply With Quote
Old 04-15-2008, 06:58 AM   #8
custom72c20
custom72c20's Avatar
that sounds like what happend to me. take the distributor cap off and look inside. mine had a hole in it where the rotor touches the coil. (HEI)
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 04-15-2008, 09:03 AM   #9
BurnoutNova
BurnoutNova's Avatar
my 67 did somthing similar to this when i first bought it. it idled great, but going down the road it would act like it was running out of gas. the fuel filter was totally full of crud. replaced it and it runs great now.
BurnoutNova is offline   Reply With Quote
Old 04-15-2008, 10:37 AM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I thought it sounded like a bad positive cable or the power lead coming off the starter?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-15-2008, 12:31 PM   #11
BurnoutNova
yeah, with the way it had nothing at all till he tightened some stuff up... it probly has more than one issue (like ALL my vehicles )
Old 04-15-2008, 02:30 PM   #12
Originally Posted by Longhorn Paul View Post
After a few months of problem free ownership on the way home my 69 started rough idling and then just died. Right in the middle of a busy road. *Wouldn`t turn over.Nothing. Got under the hood, moved a couple wires, nothing. Called for a tow. Tried again. Got the starter to fire. She coughed to life, got her to the mechanic.
*Are you saying you turned the key and there`s no click or anything at the starter?That is probably a bad connection or corrosion at the battery/starter cables or connection to the ignition.If the battery had full charge,it was likely the battery connection to the starter.
Tigthend a few wires, started & stopped her 4 times. No issues. Left the mechanic... 800 yards down the road she just died - engine just quit. Would not restart. *Turned over fine,but wouldn`t start. Took the gas cap off (vapor lock?). Didn't help. Tried starter fluid: fire for a second or two and die. Seems like she's starved for fuel.
*So,it was cranking but not firing?If you`re getting fuel all the way to the carb and the filter in the carb is good,it could be a bad accelerator pump.
It sounds like two seperate issues.
Old 04-15-2008, 02:52 PM   #13
GruntyPants
GruntyPants's Avatar
Paul,
I know it sounds standard, but do you have a good ground? Seriously check both battery cables. Those things will oxidize beneath the insulation and be useless even if they look okay. Double check your ground connection to the engine block too, take it off and wire-wheel the bolt and connector to make sure you really are getting a connection. The positive connection on the starter needs to be checked and cleaned as well.
The fuel system checks are just as valid, but if the truck dies then won't turn over at all, it's definitely electrical.
Shawn
Shawn
'67 Short Step
'70 Short Wide
GruntyPants is offline   Reply With Quote
Old 04-15-2008, 06:59 PM   #14
Yukon Jack
Yukon Jack's Avatar
After having my K5 do very similar things I replaced the fuel pump and my problem was solved. I think it was cdowns who recommended pulling the fuel line and see who much fuel it was pumping to see if it was going bad. My post on my issue would be about a month old in the engine subforum.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-19-2008, 02:47 PM   #15
Longhorn Paul
Mine's longer
Thanks everyone for all the solid advice and suggestions.
The rig had been upgraded from mechanical to electronic fuel pump and when that was done the fuel lines had been re-routed. Apparently, they were too close to the block? and got hot. That, combined with a replacement gas cap (from napa) that was unvented caused a vapor lock and starved the motor.
Looks like I had a combo problem - vapor lock w/ a loose wire (which wouldn't allow the starter to fire). The appeared connected but they weren't. The day she died on me was the warmest day I'd had her out so it all seems to fit.
Thanks again for the help.
Paul
