04-18-2008, 11:38 AM | #1 |
ls 376/515
I am looking at engine options for my c10 and was thinking about a ls crate engine. I was lookin at the 375 cu in 515hp all aluminum model. I feel kinnda ify about that engine because of the block, how much power can the aluminum blocks handle before they warp or brake? and how long (assuming I dont beat the hell out of it) would this engine last? I listed the specs of the engine below
Part number: 19171225 Balanced: Internal Block (P/N 12584727): Cast Aluminum with 6-bolt, cross-bolted main caps Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92mm) Camshaft duration (@.050 in): 226 degree intake / 236 degree exhaust Camshaft type (P/N 12480110): Hydraulic rolller Compression ratio: 10.7:1 Connecting rods (P/N 12617570): Powdered metal Crankshaft (P/N 12597569): Nodular Iron Cylinder heads (P/N 12598594): LS3 rectangle port; as cast with 68cc chambers Displacement (cu in): 376 cu in (6.2L) Engine type: LS Series Gen IV small-block V8 Pistons (P/N 19165089): Hypereutectic aluminum Maximum recommended RPM: 6600 Recommended fuel: 92 octane Reluctor wheel: 58x Rocker arm ratio: 1.7:1 Rocker arms (P/N 10214664 exh): Investment cast, roller trunnion Rocker arms (P/N 12569167 int): Investment cast, roller trunnion Valve lift (in): .525" intake / .525" exhaust Valve size (in): 2.16 int / 1.59 exhaust
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
04-18-2008, 04:30 PM | #2 |
On a budget like Fred Sanford
Re: ls 376/515
You're a long ways away from having to worry about the block failing. There's guys running 800+rwhp on stock ls blocks. The cam will be the limiting factor in that package, it's barely using the head flow. The LS3 heads have a TON of potential and have as-cast flow numbers in BBC territory......throw a .650" lift cam in there and you're talking 600+hp easy. If you've got any lsx related questions I'd be happy to help.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 04-18-2008 at 04:57 PM. |
04-18-2008, 09:00 PM | #3 |
Re: ls 376/515
Same here.. I have been tuning the LS1's since 2001 (For personal and friends) as well as building LS1 stuff for personal and friends for quite some time.
There are turbo cars going bottom as fast as bottom 8's on stock blocks and cranks. The l92 heads (LS3 heads) are incredible right out of the box (But you need at least a 4.00" bore). My little 347ci motor with 3 year old factory (ported) LS1 heads is making 430rwhp through a 4L80E (heavy auto). This is with an off the shelf cam. I will be hitting this block/stock crank with a 300hp shot of N20.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 04-18-2008 at 09:01 PM. |
04-18-2008, 09:48 PM | #4 |
Re: ls 376/515
A top fuel has 8000hp, and it runs an aluminum block.
Like the others have said, the LS series block is more than tough enough for what you want to do. |
04-24-2008, 04:17 AM | #5 |
Re: ls 376/515
I don't mean to be a wise guy or anything......But, a BBC will make more power, and be cheaper than an all aluminum LS project...Don't be mad at me, just trying to save you a few bucks...
A.........
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
04-24-2008, 04:51 AM | #6 |
Re: ls 376/515
Agreed, but a LS1 is A) lighter B) easier to get the most out of it with the laptop tuning and C) has a cool factor people love when you open the hood..
Back to ya, don't get mad.. It's different strokes for different folks.. BTW, I have seen a few 418ci LS1's making over 550-570rwhp. Thats on par with some of the more radical pump gas big blocks I have seen.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
