Old 04-18-2008, 03:52 PM   #1
twotrucks
Junior Member
cab mount bushings
I need info from those that have used the aftermarket cab mount kits that various board vendors sale. Question is should there be a washer on top of bushing (between the bushing and cab floor) for the front mounts. The kit I have does not have a washer large washer that will fit the bolts supplied. It does have washers that obviously go with the conical bushing at the nut end of the bolt. I have an assembly manual and it shows a washer above at the cab floor but these are aftermarket. The hardware supplied is yellow cadmium plated but have no marking at all on the heads?
twotrucks is offline   Reply With Quote
Old 04-18-2008, 04:16 PM   #2
71MUTT
Can't ReMember
71MUTT's Avatar
Re: cab mount bushings
Adversity doesn't test your character; it reveals it.
71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running )
71MUTT is offline   Reply With Quote
Old 04-18-2008, 05:46 PM   #3
twotrucks
Junior Member
Thanks for the pic and it agrees with the assembly manual however it is the original style bushings. I have the aftermarket type.
Old 04-19-2008, 03:58 PM   #4
twotrucks
Junior Member
Anyone have dimensional details of item 13 square washer that is shown in the LMC catalog. Vendor has informed me to re-use my old ones, trouble is I don't have any and would like to just make the two I need.
Old 04-19-2008, 04:04 PM   #5
bedsled71
bedsled71's Avatar
i just put mine back on, its like 3 x 3
bedsled71 is offline   Reply With Quote
Old 04-19-2008, 04:42 PM   #6
twotrucks
Junior Member
3 x 3 x thickness?
Old 04-20-2008, 05:13 PM   #7
twotrucks
Junior Member
Anybody else?
Old 04-20-2008, 05:29 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Went out and measured my new ones and they measure 2 11/16" x 2 11/16" x 1/8" thick and have a 3/4" hole in the center...
LockDoc
Leon
Old 04-21-2008, 05:44 AM   #9
twotrucks
Junior Member
Thanks LockDoc.
Old 04-21-2008, 06:09 AM   #10
LockDoc
LockDoc's Avatar
No problem...
LockDoc
Leon
Old 11-23-2008, 09:06 AM   #11
jlaird
jlaird's Avatar
Does anybody know how thick the rear upper washer (number 22 in the diagram) is?
I also have a question about number 12. Is that a small washer that goes under the head of the bolt inside the cab, or is that another large washer that sits on top of the square washer under the cab?
jlaird is offline   Reply With Quote
Old 11-23-2008, 09:42 AM   #12
70 net440
Junior Member
70 net440's Avatar
Number 12 goes between the head of the bolt and the inside of the cab floor. Not sure how thick #22 is, about 1/8" I think.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 11-23-2008, 12:53 PM   #13
abadsvt
abadsvt's Avatar
This is not a for sure answere but i am pretty sure that they are the same thickness for the front and rear washer. I am talking about the "shim/washer" that goes on top of the body mount.
The small washer that you are refering too goes inside the cab and the bolt goes through it. The cab actually has a small recessed spot for the washer.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
