05-22-2002, 08:08 PM | #1 |
Trans. mechanic said 700r4 is ok in his book
Talked to a local trans. mechanic w/ a well known rep and he said the 700r4 is great choice to put in our trucks. But... He said that if you go with a 373 rear-end or lower, you need to go with the TH350 instead. The 700 works better with the higher gears. He also said that a lot of the problems concurning preformance is brought on by the individual by not getting them set up right. This board has already mentioned that. Last thing he mentioned was that if you buy one or get one rebuilt, you need to get it installed and on the road. They cant take getting set up for any lenght of time. Maybe this will help some of you on your decissions.
------------------ 68GMC SWB Gound-up restoration,350/700R4/342.... 2002 3/4 HD for a daily driver. Can't get away from the GMs
68GMC SWB Gound-up restoration,350/700R4/????.... 2002 3/4 HD for a daily driver. Can't get away from the GMs |
05-22-2002, 08:11 PM | #2 |
68cst_ss490
700r4 are good trannies there are lots on the road. the biggest problem as you mentioned are not having the set up. That goes for anything on a vehicle. If it isn't set up properly it will never work correctly.. Its your truck put what trans you want in it. I'm looking for a 700 for my 68, the perfect combination on=f driveability and performance all in one
------------------ Dean edmonton,canada 68 c10, project in works,350, th350, plain jane. SLOW AND STEADY GETS THE PANELS READY http://communities.msn.ca/MyChevytruckpage
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
05-22-2002, 08:52 PM | #3 |
Was given this 86 pu by a friend. The back rear was gone. Found two nice 373's on an 86 burb that burned. Pulled the rears, the 350 trans, the np208, the shafts, bolts, everything but the oink. Put both front and rear difs in the 86 1500. The trans would not shift. It worked fine before! I did'nt touch it. Scratched my head, talked to Lee Miles, wanted 800 to rebuild it? I parked the truck. Bought the 72 4 sp., need a 700? a 350, 2 208's near NJ?
72 C 20 350/4 sp, Ebay bargain! What's left is nice! |
05-22-2002, 08:54 PM | #4 |
68cst_ss490
would cost a lot to send a 700 up here to edmonton, canada
05-23-2002, 01:10 AM | #5 |
14.1 @ 96MPH
3.73 or numerically lower, right?
I dunno, I think a 700R4 is still perfectly fine in a truck with a 3.73 or 3.42. I'm pretty sure 3.42 is the stock ratio on almost every GM truck these days...it's what we've got in the Suburban and it's really a great ratio for a 700R4 and street-size tires. I suppose it also depends on tire size. 3.73 with 275/60-15 tires is just too many RPMs at 80mph, in my opinion. And though it's not a truck, they get put in Camaros with 2.73 and 3.23 rearends. ------------------ Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete! |
05-23-2002, 01:19 AM | #6 |
GYRO GEARLOOSE
Running a 200R4 in my 66 panel with 3.07 rear end, real nice to let motor settle down to 1750 rpm at 70 mph. 200R4 has good 1-2 shift which 700 does not.
------------------ Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
05-23-2002, 01:42 AM | #7 |
Well I have 3.73 in both my trucks and my 94 GMC has 4l60E (700r4 electornic controlled) and if you check out <a href="http://www.ring-pinion.com">Randys Ring and Pinion</a> and click on Calculator and calculate your Tire Size and Gear Ratio to 60 MPH and on that site it says 1800 - 2800 RpM is recommended for Small Blocks.
So with 3.73 Gear Ratio, and 275/60-15 Tires with following Tranny Combos and RPMs: TH350/400: 2767 RPM OD Auto: 1887 RPM 4 Speed: 2695 rpm 5 Speed: 2156 RPM 3.42 TH350/400: 2537 Auto OD: 1730 4 speed: 2471 5 spd: 1977 3.07 TH350/400: 2278 Auto OD: 1553 4 spd: 2218 5 spd: 1775 well as you can see these are basically Trannys that are set up with 3.73 Gear Ratio out of most newer trucks but with 700R4 you can have them built to run up too 3.08 gear Ratio but I would recommend leave 3.73 and just get the 700r4 and run it that way because if you are running Carb then ya don't want to lug the engine!! If you are running fuel injection then run 3.42 or higher since the computer will change Timing, Fuel and engine rpm to keep it from lugging with OD on @ 60 MPH !! ------------------ Truck #1 68 Chev LWB Fleet w/ Wood Floor (Sucks Gas and Hauls Ass!) and in process of Body Work... Truck #2 1994 GMC Sierra SL w/ 4.3L Vortec V6, 4L60E Auto!!
1968 C10 Truck LWB Fleetside 1968 C10 Truck SWB Stepside 1994 K2500 Ext Cab Fleetside 2008 Honda Civic Si *lease* |
