Old 04-20-2008, 06:16 AM   #1
72_ventura
light problem
my truck is having some light issues my lights work when i turn on the switch but when i turn the turn siganl on the tail light goes out on the left side and the right stays lit and when the right is going everything works fine then when you press the brake pedal the left goes completely out and the right works fine but when the lights are off the turn signal and brakes work as they should
i have tried changing out light switches, bulbs and changing the tail lamp buckets
does anybody have any suggestions
72_ventura is offline   Reply With Quote
Old 04-20-2008, 06:22 AM   #2
tim21391
tim21391's Avatar
Re: light problem
same exact thing happened to me....i messed with the taillight... and then when i turned my lights on and pressed brake it did the same where the left went out...flipped the right blinker and everything goes off flip the left blinker and my right ones blink.... i would take your lenses off your taillights and check the ground..make sure you have two bolts in the housing and make sure it hits the metal or whatever when you screw it in..thats how it grounds itself...i only had one bolt in my left side so i stuck a bolt in and it grounded it and fixed the problem....let me know if this worked or not
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-20-2008, 07:45 AM   #3
Mint68
Mint68's Avatar
Re: light problem
I would think it is a ground issue as well. Search the site, there is multiple threads about it. People have said that going through/adding more grounds fixes the problems and makes all the lights brighter.
Mint68 is offline   Reply With Quote
Old 04-20-2008, 07:54 AM   #4
72_ventura
Re: light problem
cool i will try that tomorrow after work and let you guys know sounds about right i have tryed everything that i can think of but that the only thing is wouldn't the whole side not work at all if you did not have the bucket grounded?
Old 04-20-2008, 04:59 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: light problem
Check this out... I had some weird problem on mine after shifting the bed around.
http://67-72chevytrucks.com/vboard/s...d.php?t=284861
68gmsee is offline   Reply With Quote
Old 04-20-2008, 06:06 PM   #6
72_ventura
Re: light problem
cool guys i appreciate all the help im going to go to the parts store when i get out of here and pick up some grounding straps and some good sand paper and try this out i will let you know if it works or not
Old 04-20-2008, 06:07 PM   #7
drbyrdman
drbyrdman's Avatar
Re: light problem
It is the turn signal switch in the steering colum I bet. They do that when they start to where out.
drbyrdman is offline   Reply With Quote
Old 04-20-2008, 07:03 PM   #8
cdowns
cdowns's Avatar
Re: light problem
there should be a grond strap from one of the crossaills of the bed to the crossmember of the frame if not make one up and install it//that solves lots of assend light problems
Old 04-20-2008, 07:34 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: light problem
There is a slight chance that it is a bad ground, however,
Remove the tail light lens on the drivers side, take the bulb out. Ground a test light on one of the 5/16 headed bolts holding the tail light assembly in place. Have an assistant depress the brake, while you check for power on the bulb contact.
*BE CAREFULL NOT TO ARC OUT THE TEST LIGHT ON ANYTHING ELSE METAL... everything that is metal there is a ground, and you'll be swapping out the fuse if you arc it*
If you have no power, then you actually have a wire issue.
Even though you just replaced it, I would swap the bulbs out, left for right, just to double chack. Lower cost lamps have been known (more than once) to be crap out of the box.
From there, i would inspect the wires under bumper... you know, where the last 3 P.O. spliced in trailer harnes plugs. IIRC, yellow is the wire you want to pay special attention to. (If I'm wrong, then it is dark green)
Once the under bumper area is OK, if the light is still bad, I would give the rest of the chassis harness (going up the dvr fraimrail up to the firewall) a quick once over and then go to the turn signal switch.
The reason the light goes out all together, is becouse the tail light part (brown wire) turns off when the bright side of the bulb comes on, this is to reduce heat, and the dim one being light up is kinda redundant anyways.
Old 04-20-2008, 10:24 PM   #10
72_ventura
Re: light problem
got the problem fixed guys thanks again for all the help....i had a bad ground added one from the frame to the bed and everything works great
Old 04-20-2008, 10:39 PM   #11
Longhorn Man
Re: light problem
good deal. Sometimes the bad grounds act like this, but usually you'll get the light on the other side acting funny in the reverse mannor.
Old 04-20-2008, 11:07 PM   #12
tim21391
tim21391's Avatar
Re: light problem
good to see u got it fixed
