04-20-2008, 07:30 AM | #1 |
Need Help With Speedometer And Building My Dash Cluster
HEY guys i,am building my new dash cluster and got everything done except turnning my milage to 0 on my speedometer. finally got my 80 psi oil gage, tach & tach tins, vac gauge, new clear lense, new bezel, new bulbs etc. now for thar speedo milage. how do you do it ???? any help is appreciated.
bob
I BELIEVE IN JOHN 3:16 |
04-20-2008, 09:58 AM | #2 |
Re: Need Help With Speedometer And Building My Dash Cluster
hey you can either hook it to a drill and rewind or go forwards or take it apart and put it back to gether, i have done both
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
04-21-2008, 09:27 PM | #3 |
how do you take it apart ?
04-21-2008, 09:53 PM | #4 |
Old member
You can take the paper clip that hold the numbers in place off and turn it back to 0 and replace the paper clip holding in place. I have a couple I have done and have them for extra's if I ever need them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-22-2008, 07:21 AM | #5 |
well i pulled the clip off and they still wont turn.... i even cmpletely removed the milage assembly and they wont turn.......
04-22-2008, 03:00 PM | #6 |
Old member
It's been awhile since I done mine but when you have it in hand you pull the roller that you want to change away from the one beside it.
