Old 04-22-2008, 02:01 AM   #1
Madmandav
Madmandav
Madmandav's Avatar
Need help with rear sway bar
Does anyone know for sure the correct way of installing one of these. It is from CCP. As far as I can tell the bushing shaft should be straight but what is the best method of getting it that way. I already had to shave the bushings down just to get the dang bolt on it to begin with and as you can see it is just barely on there. The bar bushings are not mounted to the trailing arms just yet, need to get in the right position first. Any advise?
I must be crazy, that's what the voices in my head keep telling me.
Project FROSTBITE
http://www.67-72chevytrucks.com/vboa...d.php?t=280249
http://www.67-72chevytrucks.com/vboa...d.php?t=287407
'72 Chevy longbed
'70 Chevy longbed (million pieces)(FROSTBITE)
'79 Monte Carlo
'07 Chevy HHR
'00 Yamaha V-star
'05 Monte Carlo SS Supercharged
Madmandav is offline   Reply With Quote
Old 04-22-2008, 02:24 AM   #2
Curbstone Mech
Active Member
Re: Need help with rear sway bar
It should be straight up and down, you will have to drill your own holes
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 04-22-2008, 02:29 AM   #3
Madmandav
Madmandav
Madmandav's Avatar
Should I push the bar back or should I raise the rear to get it straight? Also won't it put alot of strain at the mounting for the long bushing bolt? That thing doesn't look very beefy.
Project FROSTBITE
'72 Chevy longbed
'79 Monte Carlo
'07 Chevy HHR
'00 Yamaha V-star
Old 04-22-2008, 02:51 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Are you planning on shock relocators?. Your shocks look like mine- ANGLED!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-22-2008, 02:57 AM   #5
Madmandav
Madmandav
Madmandav's Avatar
No, the shocks will stay the same, stock, the rear is only getting dropped 3'' with new springs.
Project FROSTBITE
'72 Chevy longbed
'79 Monte Carlo
'07 Chevy HHR
'00 Yamaha V-star
Old 04-22-2008, 04:31 AM   #6
powell72
powell72's Avatar
I ran into this same problem with mine. It needs to be straight, but if you lower the front of the bar enough, it looks goofy hanging that far below the trailing arms. Plus, then you need to keep moving it forward to the front of the truck to mount the bracket ahead of the kick up in the frame. I compromised and mounted mine like this-
I figure it still will be better than no bar, and I can definitely tell a difference.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-23-2008, 02:41 AM   #7
Madmandav
Madmandav
Madmandav's Avatar
I am thinking I should just change the position of the bracket on the frame?
Project FROSTBITE
'72 Chevy longbed
'79 Monte Carlo
'07 Chevy HHR
'00 Yamaha V-star
Old 04-23-2008, 05:50 AM   #8
powell72
powell72's Avatar
That's what I would do.
Chris
Old 04-23-2008, 06:02 AM   #9
jorgensensc
jorgensensc's Avatar
What about mounting it on top of the trailing arms, or would that interfere with the drive shaft?
edit****
Never mind, I see that it will.
However once you put the suspension back on the ground with the bed weight won't it level the bar out some? Personally O would wait and put it on when I had the truck back together with the weight of the vehicle. THat is what I did on our Bel Air. JMHO.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-23-2008, 06:47 AM   #10
jhow66
jhow66's Avatar
Do you mean "CPP"? I put the front and rear kit on my '72. Will get some photos . You need to have the weight on the truck when installing the rear. They should have come with instuctions. They sure do make the truck much more stable.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-23-2008, 01:32 PM   #11
Madmandav
Madmandav
Madmandav's Avatar
Yes, CPP.
Project FROSTBITE
'72 Chevy longbed
'79 Monte Carlo
'07 Chevy HHR
'00 Yamaha V-star
Old 04-23-2008, 05:38 PM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-24-2008, 05:41 PM   #13
70c10
67-72 Addict!
70c10's Avatar
Look here:http://www.classicperform.com/Instru...PDF/CP7401.pdf
Says drill a hole 20" from oval along frame rail and 2" up from edge. Lowered trucks may need to be modified according to directions.
Jim
Old 04-24-2008, 07:05 PM   #14
jhow66
jhow66's Avatar
Mounted mine the way 70c10 shows- works great.
Old 04-29-2008, 05:41 AM   #15
stnman
stnman's Avatar
6072TTA 60-72 Trailing Arms Only Pair I'm using cpp's tube style arms, no provisions for swaybar, I know with minor fabrication this will work, but has anyone done this yet? Don't want to reinvent the wheel if someone already has!
stnman is offline   Reply With Quote
