04-22-2008, 02:32 AM | #1 |
Upper rad hose ?
I just noticed when I was washing my engine compartment off that my upper radiator hose was flat, no cooling problems, tank full, overflow full, when I took the cap off the hose retook its previous form, a bit flatter. I noticed that alot of our trucks had a solid almost pipe in place of a hose, can I find one of thodse or does anyone have a suggestion for a solution?
Scotts72C10 |
04-22-2008, 02:56 AM | #2 |
its all about the +6 inches
Re: Upper rad hose ?
the pipe is supposed to be on 4X4 trucks, the 2 wheel drives never had them *as original*.
This really isn't an issue. once you fire it up and it builds pressure, it'll inflate. If it bugs you, then I guess a new hose would be the answer. |
04-22-2008, 03:01 AM | #3 |
Well there you have it, doesent bug me with the hood closed, I`ll just keep it that way.
Scotts72C10 |
04-22-2008, 03:46 AM | #4 |
you can put a wire coil inside to keep it round.
04-22-2008, 03:55 AM | #5 |
Your radiator cap is not working right or is not vented. There should be a little round valve in the center of the cap that will let air back into the system when it cools down, preventing the vacumn that sucks the hose shut.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-22-2008, 03:59 AM | #6 |
Active Member
I wouldn't just forget about it, though... If it flattens out too much, it may be time to replace it. There's a lot of pressure in a hot radiator for a weak hose and could leave you stranded.
I've never noticed it on either of my trucks but I have replaced the hoses a couple of time since I had them. |
04-22-2008, 06:24 AM | #7 |
I`ll change out the cap and hose tomorrow, I was just kidding about not lifting the hood.
Thanks all, great info
Scotts72C10 |
04-22-2008, 06:28 AM | #8 |
if it has the original style cap, it'll let pressure out, but not back in.
The spring is a band aid fix. It is intended for the lower hose where it is under a partial vacume condition when ever the engine is running. I've seen this before, and it bothered me on one of my trucks, but being lazy and cheap, i let it go for about 3 years with no issues. I was advised that it was normal back in the day. |
