Old 04-23-2008, 04:54 AM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
205 loose yoke
Ok a little background............
I bought a 465/205 setup from a buddy. I installed it into my 72 blazer with a 8" suspension lift, I have always had vibration coming to a stop, would vibrate the truck quite a bit, I drove it like this for 6 months as my daily driver until just recently I was able to afford a High Angle Driveline cv shaft for the rear. I also had a nasty gear oil leak since I got the thing, Ends up the t-case adapter was cracked at the top of the mounting flange. i pulled it too and had a machine shop weld it up.
Today, I finally get everything installed and hop in to check out my ride with the new cv shaft. coming up to the stop sign at the end of my street I got the same nasty vibes as before. I turned around and pulled back into the driveway. I took out the angle finder and the axle yoke is 18* and the driveline is 20* I went to check the output flange and the whole thing moves up and down about 1/8-3/16" so what does this mean? what Am I looking to replace here? It has a fixed flange.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 04-24-2008, 04:45 PM   #2
scejmer
scejmer's Avatar
Re: 205 loose yoke
are you talking the front or rear shaft of the t case, just resealed mine, growling noise in 4 wheel, found bad bearing behind front shaft yolk outside bearing, $34 bucks, $25 for complete seal kit back together,
scejmer is offline   Reply With Quote
Old 04-25-2008, 07:12 AM   #3
old man jimmy
Re: 205 loose yoke
When you get your vibration. Is it when you put on your brakes? If so, it's more than likely just warped front rotors.
old man jimmy is offline   Reply With Quote
