Old 04-24-2008, 01:21 AM   #1
6bangr
Need Help Finding Choke Thermostat
Im having trouble finding the choke thermostat for a 69 straight 6 250cu. single barrel carb for my c10.
I want my motor to idle as proper as possible and think that'll help a great deal I just cant find the dam thing. thanx
6bangr is offline   Reply With Quote
Old 04-24-2008, 06:53 AM   #2
Big D
Big D's Avatar
Re: Need Help Finding Choke Thermostat
I had a hard time finding one too. I ended up getting one from the local NAPA, but it had to be ordered.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 04-24-2008, 04:39 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Do you have a manual choke and want to convert it or do you already have the carb setup for thermostat control choke? Mine came with a manual choke setup.
I believe someone has asked this before. Might do a search and see what comes up. Maybe someone else remembers...
LMC carries a choke for a 72 six. I'm not sure if it's the same as a 69 but maybe someone here may know.
http://www.lmctruck.com/icatalog/cb/full.asp?page=126
68gmsee is offline   Reply With Quote
Old 04-24-2008, 05:32 PM   #4
Luvlegs
Luvlegs's Avatar
Last I could tell, there are a least two different types - one goes down between the head and the intake and on my 72, it's on top of the intake (which makes absolutely no sense to me but it is what it is). I'll TRY to post a pic here of mine.....
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 04-24-2008, 05:40 PM   #5
Luvlegs
Luvlegs's Avatar
The first isn't mine - the choke rod goes down in between the head and intake - you can see mine in the second pic, it's on top of the intake
1972 C10 L6 3OTT
