Old 01-28-2003, 08:26 PM   #1
Blue Beard
Blue Beard's Avatar
A\C - Defroster Problems
Having problems with A/C and Defroster.
When trying to get the defroster to work the air just keeps coming out the air ducts.
Replaced all the duct work, checked the vacuum lines. and electrics seem to be working okay.
Any help at this point would be way beyond a big help.
Blue Beard
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-28-2003, 08:28 PM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
the door is broke in the diverter. the big black duct under the dash, the door breaks right at the pivot rod. when you move the lever, the rod turns, but the door just stays there
i fixed my with some really good apoxy and 2 large washers. or you can just buy a new diverter.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 01-28-2003, 08:43 PM   #3
Andy4639
Old member
Andy4639's Avatar
This is what I would check first. The cable on the front side of the heater vent, where the air should blow out. Look at the cable and make sure it is hooked up.On mine the screw holding it had come out. The cable was just sliding back and forth. Take your hand and work it back and forth and see if it makes any difference, if not the your flapper inside is torn. You can try and fix it are do as I did and buy a new one.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-29-2003, 12:44 AM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
mtdave2 is right...the door is broken! If you take the box off you will see you can hold the door and turn the shaft. It fools a lot of people when they see the shaft move on the outside, they think it is working.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 01-30-2003, 08:45 AM   #5
GREEN70-72
GREEN70-72's Avatar
OK OK MINE IS BROKE, FIGURES, SO WERE CAN I GET JUST THE DIVIDER AND NOT THE WHOLE BOX ASSEMBLY? I WOULD LIKE TO JUST REPLACE IT INSTEAD OF TRYING TO FIX IT. ITS BROKE GOOD!
THANKS CHRIS
GREEN70-72 is offline   Reply With Quote
Old 01-30-2003, 10:59 AM   #6
bmg
bmg's Avatar
No one sells just the flap....you have to buy the whole diverter or fabricate one..i have same prob and till summer i just taped it shut or open can't remember to get heat out of the top defrosters. "Ricks" offered me a steal but i could not afford it 65.00 for the diverter box.
bmg is offline   Reply With Quote
Old 01-30-2003, 11:27 AM   #7
Blue Beard
Blue Beard's Avatar
Ricks
bmg:
Is Ricks a company that sells the diverter box?
If so, do you have a web address or phone number.
I too may be in the need of one. Currently having problems.
There was a post on using strong epoxy on this unit.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 01-30-2003, 11:36 AM   #8
mtdave2
mtdave2's Avatar
really its not hard to fix.. 3 years now still working fine
69 k10 Suburban
Old 01-30-2003, 02:01 PM   #9
Hutch
Hutch's Avatar
Just get a new diverter box.
GMC Pauls has em.
GMC Pauls
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 01-30-2003, 05:33 PM   #10
bmg
bmg's Avatar
http://www.****************.com/
there is the link to his site, i had called about 7 months ago tho sure the price went up.
Old 01-30-2003, 08:10 PM   #11
GMC Jim
GMC Jim's Avatar
fixed the flap with fiberglass cloth and expoxy resin.... stonger than new; works fine...... get the resin and cloth from a boat dealer.........Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
