Old 04-28-2008, 11:27 PM   #1
bdmcgee
bdmcgee's Avatar
Exclamation voltage regulator question
I'm re-wiring my truck, bumper to bumper. Can I just throw out the old voltage regulator out and replace it with a new, modern alternator with the regulator built in? I can’t see where that would be a problem since I can direct wire the new one. Where am I wrong? Thanks
bdmcgee is offline   Reply With Quote
Old 04-29-2008, 12:01 AM   #2
neonlarry
neonlarry's Avatar
Re: voltage regulator question
No problem with that. That's how I did mine when I rewired. Works much better. Just make sure if you use one of the newer CS type alternators that you wire in a resistor in the exciter circuit, 14V will eventually burn it out.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-29-2008, 01:28 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is no reason to get a one wire, and quite a few advantages of a GM 3 wire. Converson kits are avalible, and if you look around, there's plenty of posts (try the FAQ section) with how to convert it without a kit.
Old 04-29-2008, 01:50 AM   #4
TonyJohnson
TonyJohnson's Avatar
Here's the classic faq thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
