56 on 80 short 4x4 frame
Hello group
sorry for being so long getting back been at work on truck with little time off attached picture of frame showing the piece of modified 2x6 retangular tubing we added to make cab set level we then used the origional cab mounts from the 56 were it to do over again would probably take 1 inch out if the frame between the two cab mounts Gene |
![]() Join Date: Mar 2008
Re: 56 on 80 short 4x4 frame
Frame looks good. Going to be a fun truck when done.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
It will look something like this
but have since acquired a really nice big window cab |
AS I said before would cut one inch out of the frame under the cab
then take the 2 x6 retungular tubing and cut on the bottom to sit in the space where theold cab set leaving what amounts to a straight frame (with small kickups over the axels ) This will allow you to remove the cab mounts from your old frameor obtain some and position and weld or bolt to new frame some simple angle iron brackets for the radiator support One suggestion If replacing bed wood consider getting wood and strips for 73 up chevy to match holes in frames also reinforcemet strips and sills of getting new bed sides or replacing strips then get ones for 73-87 also then you can use the larger 1/2 inch bolts and they will go in old holes in frame . May have to slot a little I got all my bed parts from Mar-K in Oklahoma City and they workded well Another thing if this is to be a driver : I would consider putting linex on the bed boards before assembly then use stainless strips we have not found a stain /varnish that will stand being outside in our Texas Summers and the black andstainless contrast nicely Gene Sharp Last edited by Gene Sharp; 06-01-2008 at 05:20 AM. |
As to the Steering I am using a flaming river tilt column the same diameter as the stock one makes everything fit lots better
just measure up from drop in cab and set it about the same am using the stainless sure - fit intermediate shaft from Flaming river looks good and the sliding feature makes fit lots better On this truck went with an AGR box with the quicker ratio Have one on my Jeep and it sure makes it handle nice and no slop from a worn box used Rancho 9000 Adjustable shocks all around with a 2 1/2 inch lift kit to clear 12x33 x15 tires on Mickey Thompson Classic II Wheels Gene Sharp |
Here is a picture of the 56 as it looks now
new floor. steps, and rockers and 2 1/2 inch firewall setback by Gene Robertson Auto Body in Amarillo Texas Gene Sharp Last edited by Gene Sharp; 05-22-2008 at 06:54 AM. |
Very nice.
Kim |
Yellow truck club
I like the work so far. Nice big window cab.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
quick shot of th bed
floor and bed sides from Mar-K in Oklahoma City I used floor and stainless bed strips from a 73 to 87 short chevy pickup to match the frame I woudl also if doing it again get them to weld on the stainless strips that are tacked to bed sides for a 73 to 87 would make it easier to line up with cills and reinforcements Used two extra reinforcments and 1''pollly bushings under the bed used stainless button head bolts to assemble and Lined with added stuff to make it shiner from Line x of Chickahsha , Okla they did a super job Getting letters on tail gate painted in the same 76 Chevy Pickup blue as the top of dash Gene Sharp |
Man it's coming around quick. Look'n good.
rear view of 56
note the Blazer rear cross member we transplanted so gas tank would be mostly a bolt in If you were doing a street truck you could move rear crossmember a little further foreward and use a roll pan Gene Sharp |
Anyone know of a good source for a new gray big back window
for 56 truck somewhat in my area to avoid huge shipping cost Gene Sharp |
Another view of the gas tank supports
this one a Blazer one too a piece of angle iron welded in and the tank support welded to it to compensate for the kick up in the pickup frame the blazer doesnt have this keeps tank level then bolt in Blazer tank next time we will talk about tank a little Gene Sharp |
what kind of sound insualtion did you use? I can barely see some on post #6, also is that a brush on bed liner or spray on.
Email me at memo_43@yahoo.com, That what i can email you the pics of the gauges. I don't know how to resize them. nice truck BTW. memo
Memo S. Retired US Marine Family Man |
#15 |
the sound deadener is Hush Mat available (by ordering ) from O'Reilley
The bed liner was a spray on put on by Line X of Chicksha ,Oklahoma It has an added ingredient to give it more shine They did a really good job I also had underside of back fenders coated with Rhino liner and also had a bed liner material sprayed on underside and inside floor of cab Gene Sharp |
#16 |
Accidental;y got my shadow in the picture
and did not have time to go re shoot it this is an 86 blazer gas tank repacement and new pickup sender unit the 87 blazer came with EFI so that sender woudl be an option and might just work with the other Injection systems by substuting a different fuel pump ? as to the guage the ohms are different do am using a hole saw to drill out hole in the little round indention you see in lower right corner and installing a stock type sender probably one from a 53 as that is what I have used before with success I believe all the older trucks used 1-30 ohm senders ? then just a matter of bolting it in place What I like is when done it looks like it had always been there and is easily replaceable Gene Sharp |
#17 |
forgot ,,,,,,,,,,,unsolder fuel fill neck cut off and reinstall
so you just have little fill neck sticking straight up then a piece of ruber hose up to fill cap in bed Gene Sharp |
#18 |
got a nice guage set with 140 speedo and tach
looks really good am excited about putting it in Gene Sharp Last edited by Gene Sharp; 05-30-2008 at 02:58 PM. |
#19 |
I am sold on those Gauges! Who sells them?
http://67-72chevytrucks.com/vboard/s...d.php?t=212604 Last edited by GATORBUILT '59; 05-30-2008 at 04:24 PM. |
#20 |
I got mine from Classic parts of America
I think Brothers and Tuckers also have them I believe they are made by Classic instruments They are not cheap but I chose them because for me they have the perfect blend of clssic style with modern guages and look like a factory tach "Super Sport" type setup would have looked in 56 Perfect for a "loaded" truck Gene Sharp Last edited by Gene Sharp; 05-30-2008 at 06:43 PM. |
#21 |
here is a link to where I got mine
http://www.classicparts.com/New-Item...oducts/166/2/0 also available in Gray white and tan Gene Sharp Last edited by Gene Sharp; 05-30-2008 at 05:47 PM. |
#22 |
couple of pictures of new Dash trial fit
Gene Sharp |
#23 |
That looks great. really like the blue and white.
#24 |
one of the most important things we have yet to discuss is motor
for this I chose a 350 Ram Jet from Scoggin Dickey in Lubbock Texas It is Rated at 350 horsepower and has electronic fuel injection sorta like an updated version of the old Rochesters of the 60s Corvettes (run those for years ) Since it ws designed as a replacement engine for "hot rods " it has no smog or overly complicated computer The parts team at Scoggin Dickey are the best It is equiped with a billet serpentine setup from Vintage Air called the front runner It is a good setup if you have the room The headers are the Ceramic Coated ones from Hooker with two Flow Master Mufflers behind them I plan to add a crossover pipe to connect the two sides for more torque Gene Sharp Last edited by Gene Sharp; 05-31-2008 at 04:42 AM. |
#25 |
That is really looking nice.
Kim |
