Old 05-08-2008, 01:11 PM   #1
Rokcrln
Rokcrln's Avatar
Low Buck came home on a flat bed! Need gauge help.
Yep thats right I was comming home from picking up an IRS set up for another project when my truck gave it up. Turns out the Alt. went bad and once my battery went low it all started acting funny and left me on the side of the freeway.
I did not know it was bad untill to late so now I guess I should get my voltage gauge working in the dash. Can anyone point me in the right direction to get my stock dash gauge working so I can tell when it is and is not charging?
Thanks for any help you might have.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-08-2008, 01:36 PM   #2
neonlarry
neonlarry's Avatar
Re: Low Buck came home on a flat bed! Need gauge help.
Unless you changed the gauge you have an ampmeter not a voltmeter. I would reccomend changing to a voltmeter (out of a 73-87). Otherwise first thing to do is check the two 4amp fuses in the black rubber cases on either fender well.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-08-2008, 03:47 PM   #3
suville
suville's Avatar
"Otherwise first thing to do is check the two 4amp fuses in the black rubber cases on either fender well."
Huh! Aint never seen these, got a pic?
Kevin, the color wiring diagrams should help ya troubleshoot the electrical situation and if ya need a good amp gauge I have one you prolly do too, check the printed circuit for defects and the voltage reg. but consider swapping to internal reg alt CS10 orCS12 think theres info in the FAQ section on it!
Gettin stranded is the pits!
suville is offline   Reply With Quote
Old 05-08-2008, 07:20 PM   #4
lts70
1970 Daily Driver
lts70's Avatar
I had the same problem so I drilled out the rivets of the amp-meter and placed the original gauge background on a new cheepy voltage meter from NAPA ($14).GringoLoco did the same thing in his Camaro tachometer write up that is in the FAQ. You can't even tell it’s not original, besides the needle pointing to the left instead of being centered. Then I left the positive terminal connected to the printed circuit and grounded the other side.
My only problem is that my printed circuit is not getting juice to that terminal in the cluster plug. I was told that my two 4amp fuses in the black rubber cases under the hood needed changed but I can not find them where the wire diagram shows them, by the horn and on the fender by the battery. Does anyone have or can take a picture of where their fuses are located and what they look like?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is online now   Reply With Quote
Old 05-09-2008, 01:54 AM   #5
neonlarry
neonlarry's Avatar
The only picture I can get is of them rolled up and sitting on the wheel well together. This post describes where they are:
http://67-72chevytrucks.com/vboard/s...d.php?t=152336
Old 05-09-2008, 02:36 AM   #6
Rokcrln
Rokcrln's Avatar
Sorry guys I was in a hurry at 3am before leaving for work.
I have a 92 LT1 in the truck with a 124A internal regulated alt. I am putting in a 140A unit and need a gauge that works. My stock gauge is not hooked up or are their any wires left for it. So I am thinking that the $14 Napa gauge is the way to go. Does anyone have a link to the swap?
Thanks for all the help.
Kevin
LFD Inc.
Old 05-09-2008, 02:36 AM   #7
I got left dead in the water from those teeny fuses burning out.I checked them on a hunch and sure enough could see one or both wear burned out.Found new ones and down the road we went.
They are known as fuseable links.
Old 05-09-2008, 05:00 PM   #8
lts70
1970 Daily Driver
lts70's Avatar
Rokcrln here is a link to GringoLocos camaro tach install were he goes over the voltmeter conversion.
http://www.67-72chevytrucks.com/vboa...d.php?t=251017
Old 05-09-2008, 06:57 PM   #9
BustedTruck
BustedTruck's Avatar
I like the idiot light. Basicaly you wire switched power to one side of a 194 (peanut bulb) & the other to terminal L on the alternator. When you turn the switch on the bulb is illuminated & when the alternator is charging the bulb goes out. I found this works very well. Here is the wiring diagram for a 92 corvette with an lt1
BustedTruck is offline   Reply With Quote
Old 05-09-2008, 10:26 PM   #10
SactoJim
SactoJim's Avatar
Did that same conversion on mine.......works great and easy to hook up.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
