05-08-2008, 10:41 PM | #1 |
Yet another wiper question
Been searching through the board and haven't been able to find anyone with the same problem.
I bench tested my wiper motor and it ran fine, but now when i think about it, I think i might have switched the ground and power, but it still ran. So I put it in the truck and mount my wiper linkages to it. Without any ground wires hooked up and only the power, the motor turns a little bit when the key is turned on. When the key is off the motor goes back to where it was with the key off. Now I tried grounding the ground terminals to my ground that everything else in the cab is hooked to. If i remember correctly there were small sparks when grounding the top terminal, and nothing when grounding the bottom terminal. I then tried hooking the switch up and I still have nothing when i use the switch. Any ideas??
Stock 454 & 700R4 for sale Parts for Sale: Roll Pan BBC Exhaust Manifolds Stock Spindles & Springs and More http://67-72chevytrucks.com/vboard/s...d.php?t=287817 http://67-72chevytrucks.com/vboard/s...d.php?t=291000 |
05-08-2008, 11:49 PM | #2 |
Msgt USAF Ret
Re: Yet another wiper question
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-10-2008, 03:39 AM | #3 |
yeah i'd already checked that site out... guess i'll have to take the motor out and bench test it again
05-14-2008, 01:04 AM | #4 |
update (but help still needed):
I took the wiper linkages off the motor after finding my assembly manual and seeing that everything didnt look as pictured. i tested the motor and it ran fine and parked. so i guess the linkages were just binding up the motor. as i bought this truck mostly disassembled, i have no way of knowing if the linkages are all correct. so i was wondering if anyone had any pictures of the linkages that connect everything to the motor under the cowl for a '68.
Stock 454 & 700R4 for sale Parts for Sale: Roll Pan BBC Exhaust Manifolds Stock Spindles & Springs and More http://67-72chevytrucks.com/vboard/s...d.php?t=287817 http://67-72chevytrucks.com/vboard/s...d.php?t=291000 Last edited by brian10048; 05-14-2008 at 01:05 AM. |
