Old 05-09-2008, 01:47 AM   #51
68gmsee
Active Member
68gmsee's Avatar
Re: What is the best THeft Deturent?
Originally Posted by jimmydean View Post
......The bottom line is: If someone wants it bad enough, they will bring a flatbed.
That's for sure! I remember reading many years ago about someone stealing a huge hardwood tree worth a ton of money from a guys front yard. They did it at night and no one heard or saw them do it.
And, it was in a suburban neighborhood with lot of houses! The dude wakes up and all that was left was the stump where the tree had been ...
We just need to make it as difficult as we can and not give someone an easy opportunity to steal.
68gmsee is offline   Reply With Quote
Old 05-09-2008, 02:25 AM   #52
HoupPhotography
That is so TRUE! It seems like every year during the Baja 500 & 1K the locals get a little more "risky".... They actually try to steal entire semi's with rig and all in the trailer. God for bid if you crash or break and need to leave your junk on the side of the course!
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-09-2008, 11:34 AM   #53
HUEVUDO
HUEVUDO's Avatar
I have used a coded key for my cj7, my 67, 68 , and going to put one on my 67 chevelle. It is a flat key that you stick into a open slot, then you put your key into ignition. It kills it at the starter and will not start without coded key. $69 bucks. I like it.
HUEVUDO is offline   Reply With Quote
Old 05-09-2008, 03:56 PM   #54
nac593
Where do you get the coded key? And how do you install a fuel shutoff with mechanical fuel pump?
nac593 is offline   Reply With Quote
Old 05-09-2008, 04:05 PM   #55
haysonj
haysonj's Avatar
I have a solenoid valve attached in front of the tank switch valve and it is wired to the alarm system so it shuts the fuel of when alarm is activated.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 05-09-2008, 11:01 PM   #56
brad_man_72
the boat guy
brad_man_72's Avatar
leave the keys in the girfriends car.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-09-2008, 11:34 PM   #57
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Here's mine.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 05-10-2008, 12:13 AM   #58
El Jay
Gone to greener pastures
Originally Posted by Botietruck View Post
Here's mine.
How'd them dogs get my teefs??????????????
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-12-2008, 10:09 AM   #59
Zonaman
Zonaman's Avatar
Originally Posted by Brad View Post
Zonaman, these ignitions are only 2-3 wire circuits. Is the Ravelco device just a complicated box placed in between these circuits so that all one would have to do is remove the box and reconnect the circuits?
A few facts about Ravelco
  • It's been around since 1976
  • There are more than 100,000 possible combinations for jumpering those pins- good luck!
  • All the wires are black, and it's wired to more than one circuit
  • There is no master for it.
  • They maintain that not one vehicel with a properly installed device has ever been stolen, unless its been towed.
Nothing's 100% but it seemed like my best bet and a whole lot less liability than the "monkey with gun" option.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 05-12-2008, 12:55 PM   #60
bb1979
bb1979's Avatar
half a dozen kill switches hidden all over the truck, master battery switch, fuel shutoff, and most of all park it where nobody can move it out
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 05-12-2008, 03:51 PM   #61
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I leave a book on my seat entitled "Advanced Techniques in Knife Fighting" that seems to be working pretty well....
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 05-12-2008, 05:26 PM   #62
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Unhappy Re: What is the best THeft Deturent?
Originally Posted by mrein3 View Post
I solved the problem by moving out of the Twin Cities. My dad who still lives in the Twin Cities does the following.
You need a toggle switch, a flasher, an automotive relay and some wire. Wire the circuit so when the toggle is on, and the dome light comes on, the horn flashes.
Hide the toggle somewhere where people don't expect to find it and simply arm it when you are away from the truck. On my dad's Ford van, the sliding door did NOT turn on the dome light. So he simply put he toggle inside the van and always left and entered through that door. Further he left the wing vent unlatched so when the thief tried to get in he or she didn't break anything.
The crack head finds the unlatched vent, pops it open, reaches in and rolls down the window, unlocks the front door, opens the door HONK HONK HONK HONK HONK HONK HONK HONK...
I like this one! Just a little confused on the flasher and relay. I'm thinking the flasher has the two prongs, but what relay?
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 05-12-2008, 07:59 PM   #63
Olden Days
Living In The Past
Olden Days's Avatar
I used a fuel selector valve from a duel tank truck like this. With "no electricity" it always defaults to one postion. You put a cap on that port, and run the line from your tank to the other port. install in the frame rail between fuel tank and mechanical pump. Then wire in a switch to energize the solinoid so fuel can flow.
look around for best price. I found them ranging from 23 to 55 bucks.
Olden Days is offline   Reply With Quote
Old 05-12-2008, 08:33 PM   #64
HoupPhotography
Wow, I like that thing, it seems pretty easy to install. I 'm seriously going to look into on of those!
I'm getting tired of pulling my motor everytime I go somewhere....
Old 05-13-2008, 12:24 AM   #65
JCA1972
JCA1972's Avatar
Originally Posted by haysonj View Post
I'm all for that but with my luck I'd get the wife
Thats it thats what I'm doing to mine.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 05-13-2008, 03:51 AM   #66
jimfulco
Or you could run a wire from the coil output to the driver's seat just underneath the upholstery, causing theft to rapidly become a pain in the backside.
jimfulco is offline   Reply With Quote
Old 05-13-2008, 06:29 AM   #67
WorkinLonghorn
WorkinLonghorn's Avatar
Originally Posted by IvelDesigns
i bet this sitting in the front seat would work well:
Dude, WTF is that?
That is "Sam" the world's uglies dog.Google it.There's a Sam calendar even.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-13-2008, 08:06 PM   #68
muscletrucks
muscletrucks's Avatar
What is the best THeft Deturent Warning?
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 05-13-2008, 08:32 PM   #69
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
RUST
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 05-13-2008, 08:46 PM   #70
Premium72
Premium72's Avatar
uh... i thkn ricky got the right idea!!!..
and meow...foxy mama!!..
Premium72 is offline   Reply With Quote
Old 05-09-2009, 05:51 AM   #71
BBGMC
BBGMC's Avatar
Well I'd say for cost effectiveness go to a local hardware store buy the thickest chain that will bolt to the hood and wrap around a frame horn or some other hard to get to area where a key will fit with ease and remove your coil before locking it up. It takes a little time unless your running an HEI then forget removing the coil just unhook the wires to it and lock the hood as for me I have an MSD 6AL and it come with spade connectors for the external coils so removal for me is just unhooking two wires and locking my big ass chain also I have a kill switch hidden where no one would bother to look
BBGMC is offline   Reply With Quote
Old 05-09-2009, 07:55 AM   #72
Shaky
Six in a row makes it go...
Shaky's Avatar
3-on-the-tree. Seriously. Nobody knows how to drive it anymore.
I went to motor vehicles to register my '68 Biscayne and no one knew how to work the 3-speed column linkage.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 05-09-2009, 08:39 AM   #73
Sammy
Simply install an HEI and remove the fuse after you get out. Great improvement and an easy anti theft device.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-09-2009, 09:21 AM   #74
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
yea 3ott lol
John
1999 Toyota Tacoma 4x4
Old 05-09-2009, 09:46 AM   #75
Shaky
Shaky's Avatar
Originally Posted by oldblue1968chevy View Post
yea 3ott lol
It's even better if the linkage is worn. Tough to run away when you can't make the 1-2 shift...
