#326 |
Its lookin' like a Blazer!
Re: "Slowly but Surely" Big J's build thread...
Thanks for the HBD. They're deep. It'd remove too much material. I found a new one for 89.00. I'll probably go that route.
#327 |
GEARHEAD
I wonder if they make a sleeve for those like they have for the engine vibration damper?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#328 |
I found some Speedi-sleeves but I'd have to have two, they'd sit where the seals ride. 45.00 each..... If it were cheap enough I'd go that route. Post up if you find something cheaper.
#329 |
Got a little bit done today. Mainly getting it ready to take to the media blasting place. Filled in the hole in the top of the bedside and a couple other screw holes. Someone had cut up the tranny cover where the shifter goes through so I bent that back out and welded it up.
#330 |
where you getting it media blasted and what are they charging.
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
#331 |
Before I tell who and how much, lets see how it turns out....
#332 |
Well I got it back from being blasted today. I thought I was done replacing metal..... I thought wrong. Talk about wanting to smash something. I was a bit upset, lol... I've since calmed down though. I reckon its best to find the other rust now than under my new paint in a few months. The top of the outside window frame, more bed area, tops of the bed rails around the top holes. On top of all the fun going on with that it actually started to flash a bit on the way home.... So I unloaded, at almost dark, busted out the gun and shot the epoxy. I had some light but not quite enough. First time using this particular gun too... Took me a minute to get used to it. Yep I've got some runs here and there. At least its covered and can't rust, lol.... I still have to use chemical stripper to do the outside bedsides. I didn't want to risk warping them. I'll post up some pics tomorrow. I didn't have time to snap pics.
#333 |
![]() Join Date: Feb 2000
What a bummer about the additional rust, but your right, better to find it now. Every project has set backs unfortunately. I hardly ever have anything go as smoothly as I think it should go.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#335 |
Ive got some pieces of bed floor if you need it. Know will you say where you got it blasted and do you recomend it. I am going to get my truck done when I tear it down.
#336 | |
I've got some left over from the stuff I got from Jim but I might need more, lol... thanks for the offer. Still haven't found my box of extra pumps and pulleys. For the sand blasting..... If your prepared to see the worst then go for it. If you think the metal is good enough then stick with a DA and chemical stripper..... I got it done at E&M Fabricating across the river in Madison. I do recommend them, he did a good job, nothing warped or blasted to nothing. Even got all the nooks and crannies underneath. |
#337 |
Well after staring at the pretty new white epoxy all day I'm in a much better mood. As for my new found rust, "Just a thing"......... Started tearing down one of my doors tonight. I rememberd having a issue of Classic Trucks with the order of removal, helped alot, lol.... I think after some tlc my vent wings will look nice.
#338 |
Can't wait to retire!!
That tub does look good. Can't wait until mine is at that point.
BTW...nice work.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#339 |
Hang tough J, like you said, better to find it now for sure.
You've gained skillz through all this, those rust spots got nuthin' on you. ![]() |
#340 |
Alrighty then...... A fellow board member (family member, lol) donated a truck roof to the cause with a good top windshield piece. Its the same as the blazers. Not an easy thing to remove as its held on with 59 spot welds. I'll need to pick up some new bits before tackling the existing winshield frame. I also plan on using the truck top skin to make a hard bikini top. Picked up some nos trim rings from my favorite uncle last weekend too...... Heres the pics....
#341 | |
Nice Uncle...
#342 |
#343 |
Wow...wish I had one of them there uncles like that.
#344 |
Is there enough metal to make the bend up
#345 |
That's a good question...
Last truck cab windshield frame I looked at, it didn't seem doable but I wasn't faced with zero other option's at that time, so maybe I didn't look 'enough'. ![]() Anything is possible when the need is there, you've got the skillz dude, make it happen. ![]() You need another puzzle to figure out. |
#346 | |
![]() Thank you for the skillz comment, there is always a way, if the need and desire is there ![]()
#347 | |
#348 |
Jason, don't go nuts on small holes by cutting out if the structural integrety is there. You can seal with POR15 and bondo which will prevent future issues. Cutting and welding is fine when you have no other choice structure wise but if section is solid---no real need.
#349 |
I can't wait to see the hard bikini top - sounds very interesting!
#350 | ||
![]() Quote:
![]() Last edited by Big J; 05-23-2008 at 05:48 PM. |
