Old 05-11-2008, 10:02 PM   #101
liv4fun
liv4fun's Avatar
Re: Project "Mater" build thread
Dang... You have been busy.. I guess I should come over and check it out...
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
72' Chevy 3/4 ton 4x4
99' Dodge Durango
89' Honda Accord - Commuter
liv4fun is offline   Reply With Quote
Old 05-12-2008, 05:48 AM   #102
Brad
Out of the carpool lane.
Brad's Avatar
...yes, you should have come over today Troy. You missed all the fun.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 05-12-2008, 08:28 AM   #103
HoupPhotography
Originally Posted by Blue'72 View Post
This was when it arrived home
Attachment 333448
So, are you keeping it a crew cab....... sorry I ad to, the build looks great man!
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-12-2008, 07:50 PM   #104
Blue'72
Skinned knuckles
Blue'72's Avatar
Originally Posted by HoupPhotography View Post
So, are you keeping it a crew cab....... sorry I had to, the build looks great man!
I thought about it, but getting into the back seat would have been a workout..
Thanks for the compliment Houp!
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 05-12-2008, 07:54 PM   #105
HoupPhotography
if your wife is like mine, I can image the look when you tell her to ride in the back seat....
Keep up te good work man!
Old 05-15-2008, 01:28 AM   #106
olyelr
olyelr's Avatar
takes time but ur on a very good pace gona b sharp
david
olyelr is offline   Reply With Quote
Old 05-22-2008, 09:51 PM   #107
Blue'72
Skinned knuckles
Blue'72's Avatar
Thanks David!
I steered away briefly to take care of some yard projects, but I'm back on the truck. I'll update some more pics shortly. I've got the back half of the frame ready for paint and will work on it tonight. I need to pull the rearend out of my other truck and get it installed once I clean it up and finish cleaning and painting the trailing arms.
I'm open for some advice however on the fuel tank. I have a 12 gallon S-10 tank from a truck and Brad brought me a 25 gallon tank that Livrat graciously gave me also. Both tanks are in great shape and I've cleaned them up real good already, but I'm trying to decide on which one to use. The 12 gallon tank will set in between the rails with room to spare, and the 25 gallon tank would need the rear crossmember removed. I'm leaning toward the 12 gallon, but not sure if having to fill it more often would be worth it. However, the $100 to fill the 25 gallon might be even more painful..
Any opinions??
'07 Sebring
Old 05-22-2008, 10:18 PM   #108
tobiahr
tobiahr's Avatar
you don't have to fill it all the way up every time but you will need a larger tank on longer trips (think Texas, 100 miles between gas stations) I'd go for the 25 gallon
tobiahr is offline   Reply With Quote
Old 05-23-2008, 05:12 PM   #109
Blue'72
Skinned knuckles
Blue'72's Avatar
That's what I'm leaning toward now. Thanks for the input tobiahr!
'07 Sebring
Old 05-23-2008, 06:02 PM   #110
timbojb
timbojb's Avatar
What vehicle is the 25gallon tank from? You may have answered this already but, do you plan on a side fill or floor fill?
timbojb is offline   Reply With Quote
Old 05-23-2008, 09:29 PM   #111
Blue'72
Skinned knuckles
Blue'72's Avatar
It's out of a Suburban. I'm thinking of a floor fill, but haven't really decided yet. The side marker lights have been shaved otherwise I would like put the filler behind the light.
'07 Sebring
Old 05-23-2008, 09:50 PM   #112
72cheyennesuper20
72cheyennesuper20's Avatar
Travis, With a thirsty V8, I say go with the 25 gallon. Did you buy a steel cowl hood yet?
72cheyennesuper20 is offline   Reply With Quote
Old 05-23-2008, 11:26 PM   #113
Blue'72
Skinned knuckles
Blue'72's Avatar
Ok, that settles it. I'm going to use the 25 gallon tank..
No, I highly doubt I'll be able to get that hood..
'07 Sebring
Old 05-25-2008, 02:55 AM   #114
Blue'72
Skinned knuckles
Blue'72's Avatar
I didn't get as much done today as I hoped, but I did get my gas tank in.
This is the tank I got from Livrat. It wasn't too bad inside and looked perfect after I cleaned it out. I cut and re-welded the filler neck to come straight up for the filler in the bed.
I then removed the rear crossmember and the spare tire mount and then trimmed the crooked crossmember. I don't know if it was necessary or not, but I welded in a thick pc of steel where I trimmed the crossmember for added strength.
Attachment 363249
'07 Sebring
Old 05-25-2008, 03:00 AM   #115
Blue'72
Skinned knuckles
Blue'72's Avatar
I've also got my old truck out and the bed off. I'm either going to use that 3:08 or hopefully find a 3:73. These trailing arms are nicer so I'll be using them, and I still need to remove the sway bar brackets from this frame yet.
'07 Sebring
Old 05-28-2008, 05:27 PM   #116
Blue'72
Skinned knuckles
Blue'72's Avatar
I had a little time to work on the truck this weekend. I pulled the rearend with springs and trailing arms from the old truck and got them cleaned and painted and ready to go in the new truck.
Brad, I'm going to run the 3:08 rear for now and then switch over to the 3:73 after I get it all fixed up. Right now I'm mainly focused on getting this back on the road..
'07 Sebring
Old 05-28-2008, 05:58 PM   #117
liv4fun
liv4fun's Avatar
Dang Nice!!!!!!!!!!!
99' Dodge Durango
Old 05-28-2008, 06:36 PM   #118
Brad
Brad's Avatar
Thumbs up Re: Project "Mater" build thread
Good choice.
Your project is really coming together Travis!
Old 06-20-2008, 11:04 AM   #119
liv4fun
liv4fun's Avatar
Gots new pictures?
99' Dodge Durango
Old 06-23-2008, 10:38 AM   #120
Blue'72
Skinned knuckles
Blue'72's Avatar
I'd better give an update before y'all quit believing in me..
I've got the bodywork on the cab and fenders taken care of and once the doors and hood are ready, I'll give them all a good coat of primer. I've also been buttoning up a lot of the tedious stuff on the frame and motor. I apologize that I don't have any pics to upload right now, but I'll get some on here soon.
'07 Sebring
Old 07-02-2008, 01:35 PM   #121
Blue'72
Skinned knuckles
Blue'72's Avatar
I'll let the pics do the talking..
'07 Sebring
Old 07-02-2008, 06:57 PM   #122
liv4fun
liv4fun's Avatar
Betty Betty Nice..... Lu-Key.....
99' Dodge Durango
Old 07-02-2008, 11:51 PM   #123
billdo
billdo's Avatar
what kind of paint and process basecoat clear etc
billdo is offline   Reply With Quote
Old 07-03-2008, 02:33 AM   #124
Brad
Brad's Avatar
Oh man that's gorgeous! I almost stopped by today on my way back from Seatac. Did you just do that today??
Old 07-03-2008, 07:03 AM   #125
Blue'72
Skinned knuckles
Blue'72's Avatar
Hey Brad, welcome back! Yeah, I painted it yesterday morning. You could have watched the paint dry with me..
To keep this within my budget, I'm just using Omni single stage acrylic enamel in the original color.
'07 Sebring
