Between Trucks...
PO of my truck cut the doors for speakers, so thats where mine are going to go.
He cut them for not one, but 2 sets of speakers. ![]()
Beat it to fit, Paint it to match... ![]() |
Parts and more parts
Re: Speakers in doors
I ran my wires through the body just infront of the doors (drilled a hole in the metal and fed the wire up to just behind the dash. The wire went through the front of the door (another hole drilled) and then I put rubber grommets in around the wire.
Between Trucks...
Thanks, I'm gonna go take a peak at my truck and see what's up. I already have the holes drilled in the front of the doors, just gotta figure out the rest...
Between Trucks...
I'm kind of having a hard time getting my head around this. The part about running the wires through the body, I can't figure how the wires get to the dash. It looks like the wires would be trapped behind the kick panel vent area.
![]() Join Date: Oct 2005
I had to drill a small hole in the kick panel and fish wires through. I have carpet covered kick panels, so the hole is covered. If you don't have covers you could drill low enough to go under carpet.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
![]() Join Date: Jan 2007
Also be sure to stagger the exit (from the kick panel) and the entrance (to the door) - this will allow for some slack when opening/closing the door and reduce the possibility of rubbing through the wiring...
If you want an example the PO did this on my project truck and I have the front fenders off so I can take a picture of what I am talking about... PM if you need a shot or two. |
Use grommets on the holes, or some silicone will also work so the wire isn't sitting on the cut metal of the door.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#8 | |
VA72C10
![]() Join Date: Mar 2008
Thanks! |
Tot Roddin'
According to the PO... "what are rubber grommets?"
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
snagged this pic from Rokcrln's Low-Buck build...
Not a great picture - but gives you the idea... I will try to get better pix when I get home from work tonight...and I will post them up in here... |
Between Trucks...
I went back out to my truck to take a look, and still can not figure this out. It seems like there is a double wall in the kick panel area, I have no idea how you could fish the wires through. My brain must be on vacation today.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 05-13-2008 at 10:13 PM. |
Gettin By on Gettin By
I've seen some guys that have the touch knobs, hard to explain. Contacts ends, little round nubbs that touch when you shut the door. Not sure how well they work.
I'll try to gather up a pick, i'm sure someone has an example.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
Between Trucks...
This pic helped a bunch. I didn't see where the wires were coming through at first. Thanks dude.
Gone to greener pastures
![]() Join Date: May 2007
On my Chevy, the PO ran the wires into the vent. Then he brought them out to the left and forward of where these wires exit. Kind of at the "back" of the front fender, would be the best way to describe it.
On my GMC, the installer ran the speaker wires under the edge of the carpet to the weatherstripping. Then up inside the weatherstripping for about 3" and then around the door jamb & into the front of the door.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#15 |
Drill holes......use grommets. Then with some patience and some rigid wire (clothes hanger) bent as needed and negotiated through holes, you can pull your speaker wires through. Not too tough at all.
#16 |
Got the pix when I got home and didn't get a chance to post them until now...
The PO of my project fished them through the lower cowl area - totally hidden when fenders are on and even less friction from wires... 1st pic is straight down the psgr side with the door open 2nd pic is standing in the doorway looking toward the front of the cab... If you need more - let me know. Hope that helps. |
#17 |
Nothing to see here.....
![]() Join Date: Jun 2007
Sin,
Also use a heavy gauge heat shrink between the door and the body. That will help cut down on cut wires when the door is open.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#18 |
If you want something that looks nice and is inexpensive, give this link a try.
http://www.a1electric.com/Merchant2/...t_Code=Boot-Sm
1969 Chevy K20 Custom Camper 350, 4sp, 33's High on plans, Low on funds Last edited by harrdawg54; 05-14-2008 at 06:03 AM. |
#19 |
Freeeeee Mason...
I ran mine in simple black wire looms just to be safe.
Daily Driver -2007 Chevy -Dark Blue Metallic -Regular Cab -4.8 V8 -4x4 Ongoing, Never Ending, PITA, Love of my Life -69 Chevy C/10, Camper Special -350/TH400 -Loudest System on the Board |
