Next!
Clutch neutral safety switch installation
Ok, its been a while since I took the K30 dually apart and its back together on its new frame running again. Before I break this thing a second time, how exactly should this be attached? thanks in advance
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
Next!
Re: Clutch neutral safety switch installation
So no one has a stick shift truck?
I was wondering how this truck was coming along! I just checked my '84. I had to remove the plastic and metal lower column cover panels to see it. There's a bracket next to the column that the switch bolts to. It uses a plastic bolt and nut to hold it on and the switch goes on the inside of the bracket next to the column. The J shaped rod should be turned up when installed. I'll try to get a pic of it tomorrow.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 05-19-2008 at 06:09 AM. |
Next!
Thanks!
