#26 | |
Re: Static drop lowering-totally lost!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() |
#27 |
#28 |
Smok'em Roast'em Shift'em
I plan on dropping the front 5 and the rear about 7. With a c-notch. If i go with the 7" drop in the rear will i need a big c-notch?
#29 |
you will need at least a three inch notch to be happy
#30 |
will the notch that comes in the sport truck direct kit enough?
5/7 drop http://sporttruckdirect.com/C10_kits.html |
#31 | |
#32 |
my two bits.
I did my truck the cheap way cut coils on the front for about a year. Cool for a little while but 2.5 spindles 2inch or 3inch lowering springs the way to go. I still cut of 1 coil on the 2" springs to be crazy. But I like my stuff slammed. The rear end for me, I use my truck daily and my work is welding. I need to haul weight if its engine or metal. I would C-notch for sure. I custom made mine. It was easy. I want the rear lower to level it out but Ill live with it. 6/6 drop. ![]() Last edited by EN*PN78; 05-14-2008 at 08:12 AM. |
#33 |
do you have any pics of the process of lowering it such as your c-notch and your flip kit?
