Old 05-13-2008, 10:21 PM   #26
Wreckless_71
Wreckless_71's Avatar
Re: What Drop?????
Ok... so we've basically told you that stance is not possible without bags... so heres what I have, I got 2.5" drop spindles up front and 4" drop coils in the rear. I cut a coil out of the front to drop it a little more and heated the rears to get a little lower. I love it, It's my daily driver and I do haul a motorcycle around. The clearance is still good enough to drive on our S!@# roads here in the northwest but plenty low that it makes me cringe when I hit a speed bump. Also it really sucks if you need under your truck for anything, the tires are 275r60/15's and they fill the wells really well.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 05-13-2008, 10:28 PM   #27
chrislehr
Engine n00b
chrislehr's Avatar
Re: What Drop?????
I went 2/4 and asked ECE how much to go to 4-6 from here.
1k-1300.
OUCH.
mostly cause it requires discs.
chrislehr is offline   Reply With Quote
Old 05-14-2008, 06:35 AM   #28
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Re: What Drop?????
Ok............here's what I have goin' on. I went out to my truck and took a few more pictures for yall to see. The truck was already at this stance when I bought it from the guy in Tennessee. I really don't know how much of a drop it already has and how to figure that out, so if anyone could let me know that would be great. I think that the truck has a great stance already, but the pictures of the rear end show that the coils need replacing, real bad. I'm just not sure what size drop coils that I need to replace them with to get the same stance it already has. Does that make sense? Anyway. The front looks like the coils were cut because nothing else on the front was replaced with new parts, i.e spindles, coils, shocks. So.....my question for the front is.......should I go ahead and replace the spindles with 2 1/2" drop spindles or leave everything the way it is and just upgrade all the bump stops, bushings, etc to polyurethane? I'm sure that would make a huge difference in the ride quality. OH, and should I go ahead and relocate the rear shocks and upgrade those as well? Any help would be greatly appreciated from yall. Thanks in advance.
jgrisafi is offline   Reply With Quote
