Key will not go to ACC.
Anyone know how to fix the key cylinder so it will move back to acc? This is in a 87 suburban.
Re: Key will not go to ACC.
I had a worn out lock cylinder in one of my trucks that did the same thing. Eventually it jammed completely and I had to replace it. Replacing it with a new lock cylinder cured the problem.
Just replace it get a steering wheel puller from auto zone and buy an ignition and key while your there, they are only like 20 bucks, with the key, slide the old one out, put the new one in, put the steering wheel back on and your done!
my short bus
cool my 87 does the same same thing wont lock in off and no acess
doesnt need a key to start but not good around the kids either glad i found this post ![]()
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
Did the cheapo fix and sprayed a ton on WD40 works great now!
Put some paper towels under it to catch drips!
Did you try pushing the key inwards or upwards or both while you were turning it? Or jiggle it a bit while you turn it?
