05-19-2008, 03:15 PM | #1 |
fuel filter?
Where is the best place to put your fuel filter between the carb. and the fuel pump?
05-19-2008, 03:28 PM | #2 |
Re: fuel filter?
I put mine right in front of the carb,and since one of my saddle tanks seems to have a lot of gunk in it,I use a really big (metal cased) one. If you put one before the pump I believe you are more likely to have problems.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
05-19-2008, 03:39 PM | #3 |
Re: fuel filter?
Try to stay up high away, from the heat, as much as you can. This also makes it easier to service/replace. Stay away from the glass ones. The idea of being able to see when it is dirty sounds good, but the potential for breakage far out-weighs that. There have been several reports from members here about that. Just like that "bug-eye" looking air filter that Edelbrock still makes. I think it is called Pro-Flo. Bad deal...big fire hazzard.
05-19-2008, 04:54 PM | #4 |
Re: fuel filter?
I try to never put a fuel filter between the pump and carb, with the exception of the stock in carb filter. I put the filters (steel, not plastic) between the pump and the tank. This way your also keeping any crap out of your pump. A filter between the pump and carb is just another source of a leak, and being on the preasure side, will most likely leak when your driving. In my opinion thats why more older fords burnt up where as the chevy's didn't seem to have that problem. Before fuel injection, when I used to go to the auto wreckers, there was always one or two burnt fords, caused by leaking fuel from the filter. On my PU I run 4 filters. one in the carb, before the pump and one for each tank.
05-19-2008, 08:56 PM | #5 |
its all about the +6 inches
Re: fuel filter?
putting the filter between the tank and pump can agrivate, or even help create a vapor lock condition by reducing the presseure between the filter and the pump. We all (should) know that by decreasing the pressure, you are decreasing the boiling boint... which, is why you raise the pressure in your cooling system, to raise the boiling point.
05-19-2008, 09:10 PM | #6 | |
Re: fuel filter?
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
05-19-2008, 09:59 PM | #7 | |
Re: fuel filter?
An electric pump is a generally accepted "cure" for a vehicle with vapor lock problems, for just that reason. Last edited by LONGHAIR; 05-19-2008 at 10:03 PM. |
05-19-2008, 10:08 PM | #8 |
20' Daredevil (Ret)
Re: fuel filter?
Dunno if it's the 'right' method or not, but I'll tell you how my truck was set up when I bought it 31 years ago, and I've never had a problem with it. I have twin saddle tanks, plus the cab tank, and the manual selector valve is on the floor near the rear of driver's door. There is an inline steel filter after the valve, on the line going to the fuel pump. Come to think of it, it's probably about time to replace the filter (and the short sections of rubber [neoprene?] fuel hose connecting everything up).
Of course, I also have the little bronze filter in the Q-jet.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
05-20-2008, 09:53 PM | #9 |
Re: fuel filter?
Fuel filter? What's that?
Oh, you mean the thing in the carb inlet fitting. I think I've been running without any other type of filter for a few years now.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
05-20-2008, 11:32 PM | #10 | |
Re: fuel filter?
