Old 05-22-2008, 01:14 AM   #1
mercman1951
mercman1951's Avatar
Dropped Spindle Brake Hose Q + Caliper Bolt Length
HI all,
I have an '86 LWB 2WD GMC, and I am in the process of installing a McGaughy's drop kit on it, 2.5" drop Spindles in front, 4" drop hangers in the rear. Anyway, the new rubber brake lines I bought basically interfere with the upper ball joint once installed. What alternatives have you used that work? I hate to bend the steel part of the line for clearance, and I'm not sure it will work. I was thinking braided steel lines...if so, anyone got a part number(s)?
thanks!
other BIG project:
http://landyachts.homestead.com/index.html
mercman1951 is offline   Reply With Quote
Old 05-22-2008, 01:21 AM   #2
JCampbell
Re: Dropped Spindle Brake Hose Q
I had to bend the brake lines a bit when I put spindles on my dually.
JCampbell is offline   Reply With Quote
Old 05-22-2008, 01:31 AM   #3
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Yup, bend it.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 05-22-2008, 01:53 AM   #4
mercman1951
Thanks guys.
other BIG project:
Old 05-22-2008, 03:43 AM   #5
mercman1951
New problem...caliper bolts form my NON-HD calipers and spindle are too short. I upgraded as a result of the spindle requirements. Anybody have a part number for the HD ones? I looked on NAPA's website but they don't specify between HD and non-HD rotors/calipers...just trying to head-off a parts counter debacle...looks like I need new ones that are 4-1/2 to 4-3/4 long. thanks again.
other BIG project:
Old 05-22-2008, 04:05 AM   #6
spr85gmc
spr85gmc's Avatar
there hard as hell to bend though. i just reangled mine they worked just fine so far
spr85gmc is offline   Reply With Quote
Old 05-22-2008, 04:34 AM   #7
mercman1951
Hard as hell..why? How about screwing them in, marking the direction of the bend, then using a vice or small tubing bender? That's what I was thinking of doing...maybe nudging it over with a small hammer/pair of vice grips?
Maybe adjusting it in a vice, making a small bend, repositioning it, nudging again, etc, till it clears?
other BIG project:
Old 05-22-2008, 05:09 AM   #8
1984 swb chevy
1984 swb chevy's Avatar
I had the same problem. I bent the stock lines but I also bought new braided lines from Summit and the ends are smaller. They will fit much better than the stock lines.
1984 swb chevy is offline   Reply With Quote
Old 05-22-2008, 05:22 AM   #9
mercman1951
Do you have a part number, or a brand name/legth I could use to do a search?
Thanks...
P.S. What about your caliper bolts? Did you need longer ones?
other BIG project:
Old 05-22-2008, 05:43 AM   #10
spr85gmc
spr85gmc's Avatar
i guess i was just scared of braking them
Old 05-22-2008, 08:16 AM   #11
Bad Karma
Magnificent bastard
Bad Karma's Avatar
I bent mine on the vehicle... It didn't take much, but yes, do be careful.
1977 Big Block Burb
