Old 05-22-2008, 11:46 PM   #1
69-72
69-72's Avatar
Factory wheel for a 72 Blazer
I have a set of factory 6 bolt rims from a 70 2wd Pickup, will they work on a 4x4 Blazer.
And....
Will 31 x10.5 tires fit on these rims without rubbing.
69-72 is offline   Reply With Quote
Old 05-23-2008, 01:38 AM   #2
Re: Factory wheel for a 72 Blazer
I believe drum and disc brake wheels are different from factory.
Old 05-23-2008, 04:44 AM   #3
69-72
69-72's Avatar
Hmm good point. I was just worried about the hub opening in the front.
Old 05-23-2008, 05:54 AM   #4
The centers are all the same.The disc wheels will go on drums but not visa-versa,IIRC.
Old 05-24-2008, 07:16 AM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
And....
The 2wd rims I've seen are 5.5 inches wide. A 31x10.50R15 needs at least a 7 inch wide wheel:
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 05-25-2008, 03:19 PM   #6
69-72
69-72's Avatar
These are the wheels I have now, not how sure how wide they are. I would just rather get rid of these and get stock ones. I thought I saw somewhere 6" wheels would work with 31x10.5 but I guess that chart proves me wrong. Does this mean I have to get new rubber in order to run stock wheels? Another thing I am not a fan of with the current wheels is the crap spray up the side of the truck from them.
Old 05-26-2008, 02:47 AM   #7
badpeanut
badpeanut's Avatar
FYI, the chart I posted above is from BF Goodrich.
The mid '70s to mid '80s GM 4x4 trucks had 6" wide wheels, but this still isn't wide enough for a 31x10.50R15.
You could go with 7" or 8" GM rally wheels or styled wheels (white spokes) to give a "factory look" (not original for our trucks but nice looking). I suppose you could even run full factory wheel covers on them if you wanted.
One of the board members here I believe has 8" plain steel wheels, but I've never seen a set of these in person.
'70 GMC LWB trailer
Old 05-27-2008, 08:18 AM   #8
badpeanut
badpeanut's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=289744
'70 GMC LWB trailer
