Old 05-23-2008, 11:37 AM   #26
72lb4x4
Re: Starting problem......sometimes dead!
Start with cheap and easy... Things may look good, but...
Charge the battery with a 2A for 12-24 hours
Fix the grounds
Fix the + connections
Get a DVM (digital volt meter) with of course the other basics and and figure out what it means and how to use it.
Don't spend any money buying ignition switches before the above.
The longest answer above is the toughest and what will lead to the actual problem.
Magic bullets (randomly replacing parts or shotgunning) will usually lose money or win the lottery (got lucky).
Get a meter, research (autozone.com for example), a wiring diagram. think, listen/read, but don't believe.
All that said, I'll offer a guess...
If the problem is intermittent without a difference in heat, suspect a loose connection. A wiggly connection can stop (the truck,or) whenever whenever it feels like it.
Without a voltmeter, and an understanding, you can only replace parts. Get those 2 things and understand, and, well then the real frustration begins...
Electrical problems are maddening, but you can spend money, or time, or both fixing them. At home, only money and time actually solve the problem. They will drive you mad.
72lb4x4 is offline   Reply With Quote
Old 06-13-2008, 01:47 PM   #27
northerngmc
northerngmc's Avatar
Well my truck would not start again yesterday.
Loose alternator belt again!
Maybe I did not tighten enough, or maybe I have a belt that is stretching. I will keep an eye on it and see if it comes loose again.
Any suggestions? Locktite!
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 06-13-2008, 07:02 PM   #28
89 crew
Put a longer bolt in place of the short bolt, then put a nut on the back side.
89 crew is offline   Reply With Quote
Old 06-13-2008, 10:05 PM   #29
muddyblazer02
muddyblazer02's Avatar
you can do a load test on your battery by hooking up your multimeter to your battery like your would do to check the battery voltage at rest. Then pull the coil wire off so the truck won't start and have a friend turn the starter over for 5-10 second.voltage shouldn't go lower than 10 volts, assuming that you started with 12.5 volts
muddyblazer02 is offline   Reply With Quote
