Old 05-26-2008, 08:07 PM   #1
caminokid
Chevy nut
caminokid's Avatar
Frame stripping. Need better ideas.
Ok so the last two days I have been stripping my frame...and I have been using wire wheels and flap discs. I have sanded some too. Is there a faster way? I also have been trying to get the undercoating off to and been a pain. Just looking for an easier way guys.
Any ideas??
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 05-26-2008, 08:22 PM   #2
zerwar
Sgt. Z
zerwar's Avatar
Re: Frame stripping. Need better ideas.
are you dealing with rust issues or dirt, mud, grease, gunk issues?
If its years of grease and grime, I used Marine clean from POR-15. It is a degreaser cleaner, strong, strong stuff. Be careful with it when you dilute it as it kinda burns your skin if you get it on there, I know this from experience
spray on, brush with stiff brush and hose off, repeat if needed. worked for me
MARINE-CLEAN™ cleans and degreases in one application without leaving residues, noxious fumes or flammable solvents
1967 Chevy SWB
1966 Malibu SS Convertible 355/420hp
700r4 and 373's with eaton posi
To deny our own impulses, is to deny the very thing that makes us human~The Matrix
zerwar is offline   Reply With Quote
Old 05-26-2008, 08:25 PM   #3
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Here's what Blue'72 made for just such a job.
But on the serious side, i have not idea.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-26-2008, 08:40 PM   #4
Blue85
Oilfield Trash
Blue85's Avatar
one word, sandblaster
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 05-26-2008, 09:25 PM   #5
Eddie H.
Eddie H.'s Avatar
I used a 3 step process. First, soak it down with oven cleaner, pressure wash, then sand blast.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 05-26-2008, 10:32 PM   #6
Primered_69
Primered_69's Avatar
I liked to use Castrol superclean, then oven cleaner, then do over. After that I went with the wire wheel but I used the tristed wire cup that wnet on the 4 1/2 inch grinder.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 05-26-2008, 10:50 PM   #7
CG
BlahBlahBlah
Dollar store oven cleaner and a pressure washer. At a buck a can you should be able to get it super clean with 20 bucks and a little bit of elbow grease. Thats how I did the chassis on my panel.
Old 05-27-2008, 02:20 AM   #8
byrd
Union Electrician
byrd's Avatar
Here is a link to what I have used for both of my frames, it is a poly-carbide wheel. Here is a link to it on harborfrieght.com (the link is to a 4.5" but, my local store carries a 4" one that fits my 4" grinder perfect, and the 4" ones are a $1 cheaper each)
http://www.harborfreight.com/cpi/cta...unction=Search
I did start out like most everybody else by using easy off oven cleaner and a pressure washer to get most of the big crap and chunks of grease, then oto the wheels on my 4" grinder
They work really well but they wear out kinda fast. I used 12 of them on my project Frank, but I did every inch of the frame,trailing arms, rear end, front suspention. It was WAY cheaper($50 vrs $200) to do it this way that blasting, but it did take several hours to accoplish.You can click on the link in sig to my build and see pics of how well they work.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-27-2008, 03:46 AM   #9
caminokid
Chevy nut
caminokid's Avatar
I dont have alot of gunk....just rust. The only gunk is the under coating. If I had a sand blaster...I would use it for sure.
Old 05-27-2008, 04:43 AM   #10
Sammy
soda/media blast
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-27-2008, 04:48 AM   #11
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Glass beads + sand blaster = win
Do not use any blast media with iron or and other hard in it, only use higher grit media.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-27-2008, 04:56 AM   #12
jayharrell
jayharrell's Avatar
there was a thread not too long ago about a sand blasting attachment to a pressure washer. Might be handy if you already have a pressure washer.
00 S10 2.2 Vin5
Old 05-27-2008, 05:03 AM   #13
ChevyDude
I took mine to a sandblaster....done!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 05-27-2008, 06:27 AM   #14
thirdstreettito
Resident of Here
Better yet, bring it to a local powdercoat place, they will usually charge an extra 25-100$ for sandblasting stuff for you before they coat it. Powdercoating is much better than paint.
~Bradley~
Miss having a truck
Old 05-27-2008, 06:50 AM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Take it to the local blaster... for the time/effort/money you will have in doing it yourself, it would be a great idea to pay someone and have it done in a day or two.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-27-2008, 11:53 AM   #16
caminokid
Chevy nut
caminokid's Avatar
I guess in a way I am being cheap...but in another way I want this totally to be done by me. I guess I want just my hands on this truck.
So its not really about the money...its a pride thing this time. I want to be able to say...I did everything. I have the time...kinda...Was just hoping for a easier solution.
You guys have come up great solutions to this problem and I appreciate all the replys!
Old 05-28-2008, 04:37 AM   #17
bigsnookmaster
bigsnookmaster's Avatar
Pressure washer,then take it to the sandblaster and spend $150.Presto,it's done.The sandblaster will get in all the places you can't,and if you disassemble the front and rear suspension, they get all the pieces easily.This is money well spent.Good luck.
bigsnookmaster is offline   Reply With Quote
Old 05-28-2008, 05:55 AM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Check out this thread...
And if you could find a big enough vat... I guess this might work as well... thread.
You could also purchase a sand blaster/soda blaster from Eastwood Co, which might make this easier.
The quicker we can find you a solution, the easier it will be for me in the future...
-Nate
Old 05-28-2008, 06:07 AM   #19
Green Machine
Green Machine's Avatar
Sandblaster doesn't affect undercoat much from what I have seen, sand just bounces off. Putty knife will scrape most of it off fairly easily, kersosene or diesel fuel will disolve it too. Mineral spirits doesn't seem to work near as good as kerosene. Guess I'd remove the undercoat and powerwash, then go from there.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-28-2008, 07:31 AM   #20
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Pressure washer from http://www.tptools.com/. $49.95. Just purchased one from them, going to be using it real soon and will keep you up to date. you do have to have a compressor though. I was told that this works great.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 05-28-2008, 05:49 PM   #21
fnoblitt
fnoblitt's Avatar
i'm like you, i wanted to do everything myself. i got this small blaster from the cornwell tool truck. if you have a decent air compressor this will work great. you'l find that you can use it to clean up a bunch of parts as well. i used aluminum oxide 80 grit.
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 05-28-2008, 07:16 PM   #22
leddzepp
Moderator
leddzepp's Avatar
Eastwood make a product that will strip off all of the undercoating. After it is cleaned up, you can paint right over the top of rust with POR 15...done!
