Old 05-29-2008, 04:55 AM   #1
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
New Chassis for the 65
Here is the stripped down new home for the 65 shop truck. Wally world moved to a new location and lost my photos. They called me the other day and said they found them at the new store. Here are the pics a few of you asked to see. It is an 84 g30 chassis with PS/PB/ A/C and 49,000 original miles. I will cut the ends off the radaitor support and weld the ends off the 65 support on to it and work back from there. Please excuse the mess. I stripped it next to my steel pile to save time double moving everything. Jerry
ClassicAutoResto is offline   Reply With Quote
Old 05-29-2008, 06:19 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: New Chassis for the 65
so was that some sort of van? I thought they were unibody?
Old 05-29-2008, 02:08 PM   #3
ClassicAutoResto
Rust Buster
1ton cube van had a 14ft box on it. The cab part was welded to the frame, but an air hammer 3 knuckles and a lot of cussing got it off the frame. Jerry
Old 05-29-2008, 03:08 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I'm interested to see how this is going to turn out....
Good luck with the project!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-30-2008, 02:49 AM   #5
ClassicAutoResto
Rust Buster
Thanks! I will post as I can get some time to work on it. Jerry
Old 05-30-2008, 03:31 AM   #6
suicide 63
I used a 1ton box van chassis and put a 79 chev cab and flatbed on about 10 years ago my biggest problem was conecting the gearbox to the column.If i remember right we used the 79 chev gearbox and heated and turned the end that hooked to the pitman arm. Good luck.
suicide 63 is offline   Reply With Quote
