Old 05-30-2008, 12:39 AM   #1
Jimbob91
Dual Tank Valve 86 Chev K-10
Hoping someone has a picture/schematic drawing, or at least a good description of tubing the fuel tank selector valve.
Bopught an 86 K-10 that needed some love...... Both tanks were included in the "needed love" section....
Apparently when they stopped using the left hand tank (big 'ol hole in that one) they bypassed the selector valve. All the hoses were removed from the selector valve, and then the next owner (16 year old) spent lots of time four-wheeling. So...I've got a new selector valve coming, I just want to verify I'll be tubing it up correctly.
Thanks for the help!
Matt
Jimbob91 is offline   Reply With Quote
Old 05-30-2008, 05:11 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Dual Tank Valve 86 Chev K-10
search for threads by Russell he had alot of problems with his years back although it was an 80 it should be the same
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-30-2008, 07:44 AM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
You've got a total of 6 hoses to hook up to the selector valve.
First off, IF your truck is Fuel infected then you will need to insure that the replacement hoses you use are rated for Fuel Infection and not just for a carbonated engine. If it isn't and your ride is, you'll rupture the lines within a matter of days if not hours.
Although there are 6 hoses, there is only 2 different inside diameters to contend with.... 3/8" for feed to the engine and 5/16" for fuel return to the tanks.
On the inlet side of the valve(coming FROM the tanks) it may be marked as to which tank hooks up where. Once you get the valve and inspect it and it's mounting area, it should be pretty self explanitory.
The only real big PITA are the 2 mounting bolts that drop into the frame from above with little to no room to get to with both your hand and a wrench.( 1/2" ratcheting gearwrench will work wonders here)
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 05-30-2008, 03:00 PM   #4
slug
slug's Avatar
did this a few weeks ago. you may also want to get some new hose clamps. the new valve will run you around $80.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 05-30-2008, 08:11 PM   #5
Jimbob91
Thanks for the info.
Before I came to work (I work offshore in the Gulf of Mexico) I got both my gas tanks and new straps. I picked up new hose clamps, fuel hoses, and will probably pick up new fill hoses, too, just because they're hard as a rock.
A friend of mine had a new fuel valve in his garage from a former truck, so that's a cheapie. Yes, it's the correct OEM part number and part. He lives in Houston and is shipping it out today, so it'll beat me home. ( I work 14 days on, 14 days off)
I'd already dropped the left hand tank to get an idea of what I needed.
I figure I'll change the selector valve after I drop the right hand tank. You're right, the two bolts look like a be-otch to get to with the tank in place.
My only concern was plugging the hoses into the correct sides of the valve, as the old valve was completely unplugged by someone in the past. When the lefthand tank developed a leak, they unplugged that tank, and bypassed the valve with the fuel hoses from the righthand tank.
Oh, pressure is not a problem. The original 305 was replaced with a carb'd383.
Hey, one more question. Is there an easy way to check the fuel gauge sending units while they're NOT installed? You know, like a resistance check or something.
I figure, if nothing else, I can plug in the selector valve, with the sending unit out of the tank, make sure I have a good ground on the unit itself and move the float up and down.... With the new selector valve, that should work, but I'd be checking the entire circuit, not just the sending unit. I'd really like to verify sending units before I mount them and have to drop the darn tanks again.
Thanks again!
Matt
Old 05-30-2008, 08:55 PM   #6
BLE 'BURBAN
Use an ohm meter to check them out. The range is 0-90 ohms resistance. Full to empty or empty to full I can never remember which though.
Old 05-30-2008, 09:15 PM   #7
Jimbob91
Perfect! 0-90 ohms is easy! That's exactly what I was looking for, on the senders. Full to empty or empty to full doesn't matter, as long as it's a semi-smooth transition.... As long as I know the 0-90 thing.
Thanks BLE'BURB!!!
Matt
