Old 05-31-2008, 04:35 PM   #1
joe231
joe231's Avatar
Pics of power steering brackets, please
I'm working on putting p/s on the '66. Any body running p/s with a short water pump, and the alt. mounted to the exhaust. I would like to keep my alt where it is. Pictures would be grand. I have found a bracket online that will work, think I might just fab something up, looking for ideas
here is the one I found
bracket linky
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 05-31-2008, 05:53 PM   #2
murdoc
murdoc's Avatar
Re: Pics of power steering brackets, please
what engine we dealing with here?
murdoc is offline   Reply With Quote
Old 05-31-2008, 07:23 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
some pics from the files....
283 stuff.
Old 05-31-2008, 07:27 PM   #4
joe231
joe231's Avatar
283 ci
jon, i saw those pics in the other post.
my manifolds are different than that second pic
that first pic might be helpful, but i can't see the p/s set up
here are some crappy phone pics of my alt set up
Name:  alt bracket.jpeg
Name:  alt bracket2.jpeg
and this looks very similar to the bracket that mounts to the exhaust manifold
CHEVY ONLY
Old 06-01-2008, 06:33 AM   #5
joe231
joe231's Avatar
ttt
CHEVY ONLY
Old 06-01-2008, 06:57 AM   #6
TimE
Hey Y'all!!
TimE's Avatar
I don't recall exactly which manifolds are on your truck but they appear to be later model ones to me. If so, you will probably have to go with a custom bracket or the (pricey) one that you posted the link for. I don't recall EXACTLY what year the SWP went away but I believe it was around the same time that the Rams Head manifolds went away. So, in short, I don't think GM made a bracket setup for the SWP and the type manifolds that you are running. Keep in mind, this is just my opinion.
TimE is offline   Reply With Quote
Old 06-01-2008, 06:00 PM   #7
joe231
joe231's Avatar
yeah, i'm not sure. these appear to be the rams horn manifolds, i think they are era correct but not sure. there is the possibility that they are car manifolds. i will get some better pics.
also my heads have no accessory holes, so that rules out some other options
CHEVY ONLY
Old 06-01-2008, 10:56 PM   #8
joe231
joe231's Avatar
better pics
maybe Tony (or some one knowledgeable in stock stuff) could shed some light on what these manifolds are out of
i'm off to look for some mid 60's-early 70's brackets....wish me luck
CHEVY ONLY
Old 06-01-2008, 11:18 PM   #9
scotts62
One day...
scotts62's Avatar
Hey Joe, did you not have the right bracket the other day?
Scott
93 crew cab build
Project 62
Old 06-01-2008, 11:22 PM   #10
joe231
joe231's Avatar
nope, the brackets i have are for a long pump
CHEVY ONLY
Old 06-01-2008, 11:28 PM   #11
scotts62
One day...
scotts62's Avatar
Ya that sucks. I will look for my brackets for you. If not ill be home well make em
Scott
93 crew cab build
Project 62
Old 06-02-2008, 01:38 AM   #12
Anthony Fremont
Anthony Fremont's Avatar
My 66 GMC has factory PS, but the pump and bracket aren't installed right now. I'll take a picture of my bracket. It's funky, it uses the front motor mount holes and sorta wraps around the block so that another bolt can go thru the bracket and into the side of the motor. I don't believe that it connects to the exhaust manifold and I'm sure that it doesn't connect to the water pump.
Anthony Fremont is offline   Reply With Quote
Old 06-02-2008, 05:38 AM   #13
pquick
pquick's Avatar
i ll have some photos for you tommorrow, i took some today.
pquick is offline   Reply With Quote
Old 06-02-2008, 05:52 AM   #14
protrash64
Resistance is Futile
protrash64's Avatar
You have a rare factory option in that heated ground cable..........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-02-2008, 08:29 AM   #15
joe231
joe231's Avatar
cool, thanks guys!!
protrash, your just jealous,
you like the color too, don't cha? red for ground and black for hot.
you have no idea how many times i have tried to hook jumper cables backwards
just one more item on my list
CHEVY ONLY
Old 06-02-2008, 09:50 AM   #16
sixtyfour
Zombie Killer
sixtyfour's Avatar
Not a very good picture, I'll see if I can get some better shots Sunday.
Click Pix
1964 C10 Long Step
sixtyfour is offline   Reply With Quote
Old 06-02-2008, 10:32 AM   #17
joe231
joe231's Avatar
is that a short water pump????
CHEVY ONLY
Old 06-02-2008, 11:13 AM   #18
pquick
pquick's Avatar
hers shots of my ps stuff
i287.photobucket.com/albums/ll134/orange70_photo/may312008026.jpg[/IMG]
Old 06-04-2008, 02:07 PM   #19
Captainfab
60-66 Nut
If you still need a pic let me know and I'll get you one of the original p/s bracket on my '66 C20. Those exhaust manifolds look to be original to me. I may have an extra set of brackets, I'll have to look and see.
Old 06-04-2008, 11:09 PM   #20
joe231
joe231's Avatar
yes please!!! lemme know if you do have brackets.
thank you
CHEVY ONLY
Old 06-06-2008, 01:37 PM   #21
Captainfab
60-66 Nut
PM sent...
Old 06-06-2008, 01:53 PM   #22
sixtyfour
Zombie Killer
sixtyfour's Avatar
No, it's a long pump.
1964 C10 Long Step
Old 06-06-2008, 02:20 PM   #23
pquick
pquick's Avatar
hope this helps....
Old 06-06-2008, 02:28 PM   #24
joe231
joe231's Avatar
very helpful, thanks
thanks to everyone for all the help
I love this place!!
CHEVY ONLY
