Old 06-02-2008, 11:07 PM   #1
cybermca
235 engine problem
hey guys,
i have a 1955 chevy truck with the stock straight six. i did some basic overhauling on it when it was purchased a few months ago and got it to run quite smoothly. it sounds like my grandma's sewing machine. my problem is when it is warm and has been driven around some, it won't start sometimes. i have done the following,:
new battery, new wires,plugs, cap , rebuilt rochester carb, new seals on all manifolds, rebuilt starter, rebuilt generator.
i am trying to figure out what i have missed. it could be a combo of weak spark and fuel problems, but they both work 80% of the time. no vacuum leaks and all new wiring up to the coil. huh????
any help............
cybermca is offline   Reply With Quote
Old 06-02-2008, 11:35 PM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: 235 engine problem
by doesn't start, what do you mean? does it crank, but not fire? what about if you spray some starting fluid down the carb first? what distributor are you using, the stock one? did you change the points and condenser?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 06-03-2008, 02:11 AM   #3
Daniel U
Daniel U's Avatar
Not sure if it applies here, but I've heard of some carbed vehicles getting vapor lock when they get warm. Never experienced it 1st hand as all of my vehicles are injected. Just a thought?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 06-03-2008, 02:15 AM   #4
55dude
55dude's Avatar
from what you have described "vapor lock" comes to mind. good ole' wooden clothes pins on the fuel line to act as a heat sink. if its "hard turning over when it's hot "starter solenoid" could be the culprit,get your ampmeter out and do a test on starter and see what the amp draw is. good luck.
55dude is offline   Reply With Quote
