Old 06-03-2008, 01:10 PM   #1
Lane
Check out his home-made power steering swap job
I meant THIS home-made job...
When I bought the truck I noticed - even just pushing it around - how the steering felt kind of funky. Started tearing into it and found this beauty:
The hole behind it:
Starting the repair:
Finished - with the CPP kit: Not having the original holes to use as guides that the CPP kit calls for made it interesting..
Lane is offline   Reply With Quote
Old 06-03-2008, 01:59 PM   #2
raggedjim
raggedjim's Avatar
Re: Check out his home-made power steering swap job
That's incredible...
Rg
raggedjim is offline   Reply With Quote
Old 06-03-2008, 02:15 PM   #3
joe231
joe231's Avatar
WOW!
what a mess, your fixed her up right nice though, kudos!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-03-2008, 02:30 PM   #4
Rogue 64
Ol' Blue Viking
One of mine used old lugnuts to space it off.
Scary!
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 06-03-2008, 02:39 PM   #5
kevindtimm
The funny thing is, he had the right idea. The frame is not strong enough to support the torque of the PS gear and so he 'gussetted' it.
Unfortunately, after he did that, what little was left of the frame was probably weaker than it was originally.
Nice job on your repair though
kevindtimm is offline   Reply With Quote
Old 06-03-2008, 02:50 PM   #6
Lane
Scary!
Yeah - there were some lugnuts in this deal too...
Old 06-03-2008, 03:35 PM   #7
joe231
joe231's Avatar
I just saw a frame that had no spacers, they just tightened the front bolts first then the back so the gear box was cock-eyed. people do some crazy chit
CHEVY ONLY
Old 06-03-2008, 03:59 PM   #8
TINKERDUKE
Thanks for sharing, that was one major bodge up
Cool repair.
Steve.
TINKERDUKE is offline   Reply With Quote
Old 06-03-2008, 04:08 PM   #9
raggedjim
raggedjim's Avatar
Lane, what are you supporting with the bricks? They make horrible jack stands... I used to use concrete blocks and about got crushed doing it...
Rg
Old 06-03-2008, 04:30 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
He didn't try welding the box on the frame?
Seriously, let me ask some questions about what you have done. I think I am seeing an unwelded crack in your repair. If so, take off the new box and fix it now. Drill a hole at the very end of the crack, then bevel the edges and weld on both sides.
Also, are the plates under the box sitting flat against the frame? If not, grind the welds while you have things apart.
I would also recommend either welding the plates to the frame or locally boxing the frame. If you box, leave things open enough to unbolt the steering gear.
I would also give a lot of thought toward sending the frame out for straightening before mounting any sheet metal.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-03-2008, 04:39 PM   #11
joe231
joe231's Avatar
with this kit, does the box only mount with 3 bolts?
CHEVY ONLY
Old 06-03-2008, 05:16 PM   #12
Lane
Rg
I was using them when I was test-fitting the I6 before I got the 5.3 that's in it now. Can't remember why I was using bricks for that purpose though.. lol
Old 06-03-2008, 05:45 PM   #13
scotts62
One day...
scotts62's Avatar
all fun n games until you cant steer or stop
Nice work on the fix, Lane
Scott
93 crew cab build
Project 62
Old 06-03-2008, 06:38 PM   #14
Lane
No - it has four, but one goes in from a different side.
Old 06-03-2008, 07:12 PM   #15
joe231
joe231's Avatar
i see 4 bolts, but only 3 go to the box, and the 4th is only bolted to the bracket, what about the 4th box hole???
CHEVY ONLY
Old 06-03-2008, 08:20 PM   #16
Iron-Butt
454 club
Iron-Butt's Avatar
Wow what a mess that was. Nice job fixing it.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 06-03-2008, 08:32 PM   #17
greg64
greg64's Avatar
Nice job Lane. I had to do something similar on my 77, but at least there was no P.O. to mess things up! I welded a heavy backing plate behind the original side rail, because these trucks (73-87) are known for cracking at this location.
But, like Fred said, if that one seam isn't welded, fix it now.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 06-03-2008, 08:40 PM   #18
Lane
Yes - the plate was welded to the frame. The spot you're pointing to is a slightly ground down weld. The plate under the box is very snug against the frame - and the one on the other side is pretty snug. I could probably do more grinding to flush it up more. I do plan on welding the plates to the frame, but hadn't thought about boxing the frame there - which is a good idea, and I'll probably do that too.
I've measured the frame front and back and it is pretty square - for such an old truck. All my measurements were within a 1/4" or so, and only in a couple of places was that far off. Not sure what the factory tolerances were, but I bet it's close. I may have it looked at anyway, just to be sure.
Thanks for the comments.
Old 06-03-2008, 08:46 PM   #19
Lane
The 4th box hole is bolted/threaded to the outer plate - and hangs below the frame rail just a little. Had to go out to the garage and look at it again.. lol It's been a few months...
Old 06-03-2008, 10:08 PM   #20
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Hey I've seen that work before is that from Bob Chopenhack's shop?? Jerry
ClassicAutoResto is offline   Reply With Quote
Old 06-04-2008, 01:05 AM   #21
joe231
joe231's Avatar
oh, cool. makes sense now, lol.
thanks
CHEVY ONLY
Old 06-04-2008, 09:36 AM   #22
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Before boxing that are, I would recommend a verticle plate welded in there as well...up and down, inside the frame rail between the bolts.
Weld up the entire plate, then box in....otherwise it looks good.
Kinda like this....sorry my 3D paint skills are not all that !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-04-2008, 10:47 AM   #23
Lane
Good idea - too.
Glad I posted this.. I think.. lol
Old 06-04-2008, 09:29 PM   #24
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I'm glad I read this post. I knew about the spacers, but didn't consider boxing. Ya'll saved me cause I hope to be painting my frame this summer.
Alan's Classic is offline   Reply With Quote
