Old 06-03-2008, 09:42 PM   #1
chevyfan87
gear ratio
i was wondering what my truck may have for a gear ratio...it is part 81, part 85, and possibly part 80. has a 305(original from the 85) with the factory 3 spd auto from the 85, also 6 lug axles (possibly from the 80 as the truck was originally 2wd) but the 81 was a 250L6 2wd...just a question...figured you guys would like the chance to think really hard
"tell ya what bub"
2000 gmc sierra 1500 4.3 4x4
too poor for the projects
chevyfan87 is offline   Reply With Quote
Old 06-04-2008, 12:10 AM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: gear ratio
if it was a half ton corperate 10 bolts, id say 3.08s. both my 86 and my uncles 85 had those, 4x4 blazers. No real way to tell but pop the cover or turn em.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 06-04-2008, 02:35 AM   #3
TeamRinaldi
TeamRinaldi's Avatar
Re: gear ratio
I agree, you could have anything. My '85 has a 305 and for a little while a longer the three speed, and has 2:73 gears. 3:73's are in a box in the garage patiently waiting their turn.
TeamRinaldi is offline   Reply With Quote
Old 06-04-2008, 08:42 AM   #4
larrystone
larrystone's Avatar
Re: gear ratio
Your truck is going to have a lot more pep off the line with the 3.73 and a 4 speed OD. My 1992 came with 3.08s and the chage to 4.10 gears converted it into a real work truck but my highway mileage when from 25mpg to 18mpg.
But I doubt you will get any better fuel mileage vs. the th350 2.73 setup except if you are a flatlander and the torque converter lock up is operative.
My 1986 gets 22mpg at 60mph with cruise control. With fuel at $4 a gallon you might want to keep running that stock 305 for I it's my opinion that some of the "high output small blocks and "big blocks" are soon going by the way of the dinosaur.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck
1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac
larrystone is offline   Reply With Quote
