Old 06-04-2008, 08:34 PM   #1
avysittinon22s
avysittinon22s's Avatar
Whats the best valves for air ride suspension?
Looking for best valves for air ride suspension. Im gonna be using 1/2" and 4 of them.
avysittinon22s is offline   Reply With Quote
Old 06-04-2008, 11:32 PM   #2
pissonNOS
senior member
pissonNOS's Avatar
Re: Whats the best valves for air ride suspension?
i used gc extreme valves and havent had any problems yet, im sure theres better and worse out there but these work for me
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-04-2008, 11:38 PM   #3
hotrodhomi
hotrodhomi's Avatar
Unless you are just doing the front or back, you are going to need more than 4. What are you trying to accomplish? Are you looking for speed or do you want something you can control and make fine adjustments?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 06-05-2008, 12:05 AM   #4
jimmydean
jimmydean's Avatar
1/2 valves are wicked fast (too fast for a usable application without modulation).
3/8 max, 6 valves minimum, 8 is best. Use the Ride Tech valve block and save yourself the trouble.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-05-2008, 12:08 AM   #5
avysittinon22s
yeah im just doing front and back Im looking for reliability
Old 06-05-2008, 04:34 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
I've heard some of the blocks need to have o-rings maintained often. I have heard good things @ smc valves. I'm planning 3/8 valves and 1/2" or 3/8" line...haven't decided 100%. Basically for about 40 bucks more for the 2 valves (6 vs 8) and about $10 more for a switch box would give you adjustment on all four bags individually, front and rear together, and whole truck dump and raise. I don't need all that, but for $50 extra, it makes sense in case i ever haul anything unbalanced or want to have a little fun at the local cruise in.
Old 06-05-2008, 09:59 AM   #7
fastbagged68
fastbagged68's Avatar
http://www.accuaircs.com/ sells a real nice valve. I am probably going to switch out my 1/2" valves to these.
fastbagged68 is offline   Reply With Quote
Old 06-05-2008, 03:16 PM   #8
jimmydean
jimmydean's Avatar
Any valve will require some maintenance due to wear and tear. I don't know that the manifold has anything to do with it.
I will warn you now (as I wished someone would have warned me) that 1/2" is too big. Some say 3/8 is even too fast more often than not. I ran all 1/2 for ease of design and install, but later had to run adjusters on everything because it was way too fast.
To give you an idea, I could only set ride height on fill because dump was to the ground as soon as you touch the switch. If I was running 150psi, even lift was too fast to have anything but full.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-05-2008, 03:58 PM   #9
ShowSS12
ShowSS12's Avatar
I agree 1/2 line a valves are to fast, and friend of mine has a 64 Impala all 1/2 line that thing hops up and dumps down fast but you can't do anything else. On my 96 Impala I did 3/8 everything (8 SMC valves from sucide doors.com) I like it alllooootttt I can fine tune it a bit if I need to and is plenty fast for me if the tank is around 175psi........
On my 72 I am plan on trying 3/8 line with 1/2 valves Which everyone says it keeps the same line I.D. or I may even do 1/2 lift and 3/8 dump.
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 06-05-2008, 04:37 PM   #10
fastbagged68
Has anyone thought of running 12 valves? My accu air system runs on 12 valves, 4 - 1/2" fills, 4 - 1/2" dumps, and 4 - 1/8" dumps. You could play with your system and also fine tune it....I have since switched mine to my lift valves in the front having 1/2" valve with 1/4" line. It works great, but I'm going to switch all my valves out to the new accu air ones.
Old 06-05-2008, 06:03 PM   #11
tds
instead of 12 valves just use slam specialties stealth valves. they should do exactly what your talking about.
http://blogs.minitruckinweb.com/1005...ves/index.html
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
